On 10/8/2025 at 7:45 PM, MrLeadFoot said:
What do they give you for a warranty?
GM says 150,000 miles or 10 years from initial service date; whichever comes first. This means I have until 2/2032 - This would be on the bottom end of the new engine. Otherwise I just get the remainder of the regular factory drivetrain warranty (I have under 2 years left).
  • Sad 1
OK, so not different than people like me who didn't get a new motor.
Just curious, how is everything else now that the new motor is i? Anything related get upended? Like, do you have rattles or creaking or anything like that since the repair? Hood, doors and bumper all lining up, and front bumper sensors and all working like they were before the engine swap?
Everything is exactly as it should be. Any less and it would need to be addressed.
That's great news. I am happy for you. One thing I would be afraid of is all the incidental issues that might go along with an engine swap, given all that they have to dismantle to swap motors in these trucks. I know with the Fords the cab is lifted off the chassis, but I think on GMs the front has to come off. So, congratulations!
A few more data points
  • Took my 22 in for the L87 recall to one of the larger GMC groups here in Atlanta - Service advisor said they had several come in broken but they did not have any fail the Pico test
  • He also said that they are going to maintain oil change pricing (@$89 for 6 qts / @$129 for 8 qts) even though the switch to the new super car oil - not sure if same across GM or just this auto group
I have a '22 6.2 ZR2 and I have had a handful of issues with this truck.  I had loss of propulsion issues about a year ago while I was on the highway and ended up thankfully coasting to the side of the road. Took about ten minutes to finally get the engine restarted. Happened one other time after getting it serviced at the dealership and they made some sort of fix and I haven't had that issue since.
My vehicle was part of this recall and I took it to the dealer a little over a week ago and I got the call last week that my truck needed the engine replacement.
The service representative said that they had an engine in stock that they'd be replacing it with so I should get it back sometime next week.
Has about 21k miles.
We have changed 4 engines that failed the recall so far. Another one is waiting to come in and countless other failures before this recall came out. It is tying up 3/4 of the shop with all this engine work. The other guys are busy doing valve bodies or pulling transmissions out to be overhauled. A Terrain engine that locked up is in the works and timing chains on an Acadia are being finished up now. General Motors will have no more customers to screw if they don't start building a better product and start taking care of the customers  that  are suffering threw another failure that GM passes off as Professional Grade. What a joke. The 3.0 liter diesels are also coming in alot with coolant usage with no external loss. We have changed two engines already and both had porous cylinder heads allowing coolant into the cylinders. That is a disaster to work on. Good job GM.
  • Sad 1
I love how they put it "For vehicles not yet displaying failure symptoms, the fix includes changing to a higher-viscosity oil, installing a new oil filter, and adding an updated oil cap to reflect the newly recommended viscosity."
"Not YET"
  • Haha 1
3 hours ago, PunchT37 said:
For your viewing pleasure?
Not sure if I should thank you or not because, based on what they found in this video on both engines, this has me thinking ALL these engines are going to blow at some point, some just sooner than others. In other words, it looks like the journals and bearings are going to wear at an accelerated rate, and we will all experience the issue at some point, and GM is hoping that MOST of them will die AFTER the 150k mile obligation they settled on with the NHTSA. Your thoughts?
Edited by MrLeadFoot
I believe you are correct. Those cranks suck. The chamfers are way too big. Roughness is bad but, how many cranks are worse than that on the many rebuilds that many bring to everyday machine shops? Stock rebuilds, hot rods, etc. Most to all seem to last anyway.
Add 0w20 oil, heat, oil breakdown, general truck duty, etc., and most will have a shorter than normal life.
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
