"combined weight" Truck, trailer, gear, gas, LP, etc.....
My combined weight (fully loaded and ready to camp, plus family on board) is a right at 13k lbs (scale weighed on an actual trip @ 12,880 lbs). I was surprised to see similar numbers on what appears to be a much smaller camper. Our camper is full aluminum framed, but it's not really an "ultralight", as it has conventional Al studs/joists, 5/8 plywood floors, 3/8 ply roof, etc.
I had all three wet tanks full (120 Gallons x8 lbs) three ATV's, one dirt Bike, one Street Bike, food, dishes, and enough clothes to last two weeks for a family of four, and the bed of the truck was lined with foot lockers that were packed with gear. It is a 23 Ft (Box length) all aluminum structure toy hauler (which wieght more than standard travel type trailers) It is 26 ft tounge to bumper. The trailer weights just over 4 grand and the truck wieghts almost 5 grand so if you do the math the trailer and truck really only had about 3000 pounds of gear in it.
I will post picks of the wieght tickets....... It was a fun drive from NC to CA.....3128 miles.
Edited by oldschool327
That explains it. Pictures can be deceiving. You and I are at almost identical total weight.
just click on add reply, and then just below the box where you type theres a section that says attachments, and you click browse on the far right, and select the pics you want to attach, or like you said, you can use photobucket
Here's my new truck and my trailer.....love both.
Very nice setup! Did you ever pull that same trailer w/ a 1500?
Yes I did and it was alright but it down shift going up a slight hill all the time......it only weights 5000 lbs. Now with this 2500 HD Diesel & Allison transmission I don't even know it's there........
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
