Looking at 275/70/18 nitto terra grapplers
boom11
ok thanks rims and tires should be here tomorrow says fed ex tracking hope n to go get them mounted tomorrow if i get them early enough but maybe friday pics to come sooooon
  • Replies 31
heres the baby...the tires do rub a bit anyone got ideas on how to trim wheel well???
Personally, I don't like trimming. I would through a zone 1.5" BL on and call it good. Just my 2 pennies though.
Trimming is alot easier and cheaper for some of us!
I second that comment, but also know money is tight sometimes. Trust me on that one.
The body lift is a pretty easy install and can be had for around $200 with rear bumper brackets.
Looks great...Perfect stance, and the 275's look great as well...good combo... What is the offset on those rims??? 0 or +14??
You may be rubbing a little beacuse Trail Graps run bigger than most in diameter
thanks guys for the input and ideas..as for the offset i think its zero...when you say offset what do you mean by that i know it has to do with rim size but could you be more specific?? and do you think the 1.5 body lift would stop the rubbing?? another option was the 3.5 rough country sup lift but i like the not to high look of the truck with the big tires
and as for the tires they are the toyo m/t's and the 275/70/18 are 33.6 inches tall so pretty big but i love them
If you do the 1.5" body lift you will not rub, I would bet on those odds. As for the 3.5" Rough Country lift, people have royally dogged that lift since day one on here. Not many reviews in favor but I have read they again have redesigned it, so who knows.
Truck looks great!
Offset is basically the distance the hub mounting surface is from the center of the wheel, also called backspace (distance from the backside of the wheel to the mounting surface).. It should say on the wheel box that it came in what the offset is ( 0 or +14) or the backspacing ( 5.0" or 5.6" )...Or even a part number would help...Love the way your truck looks, and want to duplicate the stance.
thanks guys for the help.and the MPG with these dropped from 18 to19 with stock tires and rims to about 16MPG wiht the new set up and as for power loss not really its a beast in the snow the tires dig in great so as far as i can see not to bad as far as power lose. Im looking into the body lift but i just dnt like the look of the body under showing but is alot cheaper then sup lift.
If you are reading mpg's off your DIC then it is wrong. As soon as you change tire sizes the DIC won't calculate your MPG's correctly.
As for the body lift, this was a pic of my truck with the 1.5". You can barely see any more frame than stock.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
