Thoughts on first tow with new 6.2L
Get a custom tune with 93 octane. It will be a world of a difference. ALOT of torque mgmt off the factory which does more harm than good. The 6.2 and the 6spd make these trucks a BEAST. It will put a smile on your face the whole way. That towing weight is chump change for these trucks. It should tow that thing effortlessly. The tune will help it avoid hunting for gears.
  • 1 month later...
  • Replies 41
When you are running steep grades you have to keep the engine in the torque curve to maintain speed. The overdrive gear just isn't going to cut it. Make that 6.2 sing, down shift to 5th or even 4th get the rpm's up...the engine will actually run cooler when it isn't lugging, and your trans will thank you for it.
Running hills with a load is all about power and torque management. You aren't driving a car when you are towing so don't drive it like one and don't expect it to behave like one. When pulling a trailer you have a combination vehicle. Overdrive is a torque killer, the 6.2 isn't a diesel. As long as you are below red line on the tach you are fine.
I think if you condition yourself to hearing the engine scream at higher RPM's pulling those hills, you will start to giggle driving that beast.
I just ordered my 1500 LDH. I have run heavy tractor trailers all over the lower 48...I went with gas for a number of reasons, you can run the mountains just like a diesel, but you have to make that torque at the higher RPM'S. Engines that lug and work harder than the should at lower RPM'S suck fuel and gas like there is no tomorrow.
Tom
Tom
That's EXACTLY what I had to do with my 5.3. Just let 'er sing on long grades, too. Plus, I use Aeroforce gauges to monitor engine and trans temps.
Recomended is a polite way of them telling you to use it for the best performance. Anything less with probablyb do the engine more harm then good.
If you run regular/non-premium fuel in any 6.2L engine performance and mileage will suffer. GM isn't recommending premium or E85 fuel just to cost you more money (even though you did buy a $30+k truck, did you not) they are recommending it for a reason.
I've actually heard of some pretty good results from '07 - current 6.0L testing done using premium as well.
Leave it in 5th. Gear hunting seems to hurt mileage more than faster RPMs do. If you wanna use OD, get a Duramax. :lol:
Hopefully one is in my future...
I haven't had any issues towing with my 2010 5.3 other than gear searching, fixed that wth a tune. The 08 is a 4 speed and doesn't jump around looking for gears, pulls hard and doesn't bog down at all. With 3 full size atv's on a the trailer from PA to WV twice a year you can't even tell they are back there, I would imagine that the 6.2L would be much better.
The 6.2 with the 6-speed has PLENTY of power, but I was expecting "better" transmission performance as well... don't want to derail this thread, so I'll start my own...
  • 2 months later...
Sorry to bring up this old thread. Towing any high walled RV (4000 pounds or 10000 pounds) is an issue of aerodynamics except hills and city driving. All gas engines get 7-10mpg.
There is no benefit to trying to tow in the highest gear. The 6.2L (and 5.3L, and every other gas engine except Ford's Ecoboost) makes its peak torque in the 4000rpm range. The "old days" of towing with a 4-spd trans meant towing in 3rd gear, which was about 2500-3000rpm. Today's 6-spds are allowing 4 or 5 usable towing gears instead of 3. Keep it there, in the 2200-3000rpm range. As mentioned in this thread, trying to run too low of a gear is worse for fuel economy and transmission wear. You will be rewarded with much better drivability, throttle response, and maybe better fuel economy.
Here's the problem. 65mph, 6th gear, 1800rpm. Any incline, the speed drops, driver pissed about "poor performance" and hits the accel pedal, then the trans does a double/triple downshift and makes up the speed.
Now same scenario in 4th or 5th gear, 2200-3000rpm. Same hill. Driver presses a little to compensate and is rewarded with sweet exhaust note under load and maintains speed.
The octane level refers to resistance to knock only. A higher octane gas is less likely to knock with a high compression engine but is a complete waste of money on an engine with the compression range of a gas engine in a truck. The truck weighs over 6,000 lbs. and that along with the trailer is still 10,000 lbs. that the engine is pushing down the highway. The engine develops its peak torque power at 4200 RPM's and you will not get that in 5th or 6th gear at highway speeds. Both 5th and 6th gear are overdrive gears and 4th is a slight underdrive with the transmission not havine a 1:1 gear.
I am surprised at the tall gearing people use to tow. All my gas engine powered trucks and SUV's used for towing have had 4.10 gearing and only my current Duramax diesel powered truck has a 3.73 rear end. But then the Duramax produces peak torque at 1700 RPM.
For towing it is a good idea to know at what RPM the engine will produce the most power and the greatest fuel efficiency. With my truck's diesel engine the best fuel economy is at 65 MPH with the engine at 1600 RPM. In California with a trailer I tow at 62 MPH and do not have a problem with the highway patrol. The big rigs are usually traveling at even higher speeds and it is rare to see one getting a ticket for excessive speed, most are pulled over for being overloaded.
The L9H engine is 10.5:1. That's premium fuel territory and it has been a proven fact that they do not run nearly as well on regular, low octane, fuel.
If I had to use 93 octane I would just go ahead and buy a diesel...
Well if he buys the diesel his wallet will feel a whole new world of hurt compared to just spending a little more on premium gas!
Where is that sticker? Is that on a 6.2L I don't think its on my 6.0L.
I have the same sticker, it's on the inside of the fuel door
Ryan
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
