LIVE POST: 2014 Silverado & Sierra reveal
Zane
Concur. Where's the Work Truck?
Base models rarely make for good photo ops, I doubt you'll see one in the photos for a bit yet.
  • Replies 243
4.8 gone ?
Sounds like the more muscular 4.3 V6 will take the place of the smaller V8.
Any ideas as to advertised HP for the three 2014 motors ?
Also, it sounds like there will be new drivetrain / cab configurations as well as trailering packages for the 4.3.
EPA #s should really improve for all three motors.
Should be in the upcoming weeks that engine numbers (HP/Torque) are released.
http://www.chevrolet...radovisualizer/
There's two work truck trim levels
"Work Truck 1 Features Include:
Exterior features include black front bumper and grille, 17" steel wheels, black door handles, locking tailgate handle and black rear bumper with CornerSteps.
Interior features include a 40/20/40 vinyl bench seat, vinyl floor covering, 3.5" monochromatic Driver Information Center, power locks, AM/FM Radio, daytime running lamps, cruise control and spare tire lock.
Power comes from an all-new 4.3L V6 engine mated to a 6 speed automatic transmission.
(4x4 models receive manual shift 2-speed transfer case and front recovery hooks)"
Work Truck 2
"Includes All Work Truck 1 Features, With the Addition Or Substitution Of:
Added interior amenities include 40/20/40 cloth seating surfaces, remote keyless entry, OnStar, Chevy MyLink audio and CD player.
Exterior upgrades include chrome front bumper and grille surround, 17" Stainless Steel Clad Wheels, deep tinted windows, power heated mirrors with spotter mirror and chrome rear bumper with CornerStep.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
