Hi maybe someone can help me with my engine swap issues !
I have a Silverado Sportside pickup from 1989 with a 4.3 Liter V6 engine.
I have now removed the 4.3 L engine and fixed up the engine room with new paint and wiring and so on..... and i am about to put in a 5.7 L V8 from 1989 to get better perfomance.
My Question is:
On the torque convertor it is a label with: 8653702 on.
Must i change convertor for the new engine (5.7 L), and if so are there anything else i must change ?
If so what convertor number is for 5.7 L V8 engine (Gasolin)
Best Regars from Finland
Patrik
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
