I finally did a RC level lift on my HC yesterday and had Toyo At Extreme 285-55-20 's put on. Rides great and no rubs. It took the HC from an old timers truck to a total aggressive stance. Took me a while to nerve up to do it. I don't know what the hell I was worried about. I love it.
Changed up my 2” moto fab front level to this..
4” BDS with Fox 2.5 coilovers. 4” block in rear with Fox Performance Series shocks. Fuel Trophy 18x9 5”bs, +1 offset. BFG Km3 295/70/18. Only have about 200 miles on the setup, but rides great so far. Minimal plastic trimming to front bumper valance and mud/rock guards. Tires still rub just a bit on felt liner when full turn in reverse. 0C5C7CD4-7AA8-4726-9CA7-ADB342BA54F2.thumb.jpeg.fb2255f64b473061535eb2c192cf3f0f.jpeg
Got the 2017 Redline lifted. 7" Rough Country Spindle kit with lifted struts. 20x10 Fuel Vapor wheels wrapped with 35x12.50 Nitto Ridge Grapplers.
Edited by Huntingfool
Version 2.0 “The Rebuild”
McGaughys 9 inch SS kit pushed an inch
McGaughys UCA
Movtech LCA
7-10 Fox DSC coil overs
McGaughys Traction bars with my custom made face plates
6 inch Deaver leaf packs
Fox Resi’s in the rear
Zone 1.5 body lift
TIS Forged 26x14’s
Fury Offroad 37x14.5R26
219A3403-FEDC-4732-B282-C2D26EB71E6B.jpeg.3201e04911a3b7ef68ed09601b08475d.jpeg308E7469-E48B-416F-8B98-4C520861D392.jpeg.a2b371ec7df670d2e7e548518ec60b8a.jpeg117F9F7F-6FFA-48DB-8261-E6A15D2CFFD0.jpeg.8dbc63f5d4002b53e77c0eee66f68305.jpeg73280C02-BC68-43DE-91A5-A4209E4F0039.jpeg.101ee867a48ac6ef8824073d491cd0ba.jpegCF29C2DE-2CF7-466D-A73C-7BA700DFE50E.jpeg.300b33962307a723d0b754acf84af4eb.jpeg5F73F854-2F28-4120-8131-FEB411E7A7F3.jpeg.61809e75ca1ce9722516ca9084be6b11.jpeg30A212DB-3626-4B43-BC11-4C7A845167AA.jpeg.9ff668d4997db5af17c7957eb8425c75.jpeg
Edited by CovetedStyle
  • Like 4
McGaughys UCA
Movtech LCA
Zone 1.5 body lift
TIS Forged 26x14’s
My god that is pretty.  I now wish i had my bds suspension powder coated to a different color :(
OK read through about 20 or so of the 344 pages... here is what I want to do. Was planning on doing Bilstein 5100's and leveling out the front. Then I started thinking I want to lift it up a few inches. What do y'all think is the best way doing that?  Just getting 2" lift kit (spacers and blocks) with the shocks.. or a whole 3.5 kit?  I am keeping the factor 20" tires and don't want them sticking out. Might just go with the 5100's for better ride... Let me know your thoughts and suggestions.
Goals =  Level .... 1-4" lift
On 5/2/2020 at 9:38 PM, FueledGMC said:
So here i am 4 years later and countless front end issues due to the bad angles with the Rough Country lift. I HIGHLY RECOMMEND NOT going with the 27820 3.5" lift by Rough Country. way too many issues. looking at the BDS 4" now.
Better now with the BDS 4" lift. Much smoother ride, clicking in my steering has gone away.. And i can turn again!
Did up my tire size to BFG TA KO2s 305 70s
Also added 1/4" wheel spacers on the front.
  • Like 4
This is my next upsize lift and tires any rub in the wheel wells?BTW Bada$$ truck dude!!!
Sent from my LM-G820 using Tapatalk
There is a slight rub on the plastic guard under the front bumper ONLY when i back out of my angled drive with wheels turned. I think i am leaving it alone as it will let me know if over time i get any closer to the METAL part of the bumper.
Thx!
Thx!
Right on man. I was thinking it would rub on the inner back. Have you done a norcal? Could you fit a wider rim or larger tire if so?
Have not done a norcal, but i will look into that if something starts to droop. I would bet u could go slightly large if u did though.
Sweet! Now ya got me thinking.[emoji848][emoji16]
On 8/3/2020 at 12:55 AM, That_guy said:
What’s a good 4 inch lift kit for my 2018 Denali ?
leveled now but still seems like I’m in a low rider
If you have the Magnaride, I think Fabtech makes a 4" lift that is compatible.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 3,038 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
