Having a bit of trouble with a TRS/Morimoto HID install.
Had a 2014 Sierra SLT that the following system was being used in:
9006: Morimoto Elite HID System
-2 x AMP: Morimoto 3Five DSP
-2 x 9006: 3Five 4300K $0.00
-2 x Canbus: 9006 $0.00
System was removed from the 2014 and placed in a 2015 Sierra SLT today. I can't for the life of me get the lights to work. Fuse looks good and after speaking with TRS I hit my ground contacts with sandpaper to remove some paint and ensure a good connection.
Any ideas? Did anything change from 2014 - 2015 that would prevent the system above from working?
Thanks in advance.
Polarity was switched on the signal from the vehicle to the lights.
All fixed.
-----HID FOG LIGHTS-----
Installing HID fog light bulbs in the 2014's has so far been a mixed bag. Some members have installed operated them for months without incident, while others have had their HIDs melt the fog light housings. It seems to happen across the board and isn't due to one brand running hotter than another. It might possibly be to duration of each use, with some magic number of minutes that, if you exceed, it'll begin melting the plastic. No one has really shown any evidence for why some melt and others don't. So that said, if you choose to install HID fog bulbs, realize it's a toss up on them damaging the housings.[/size
So that's the part that goes from the factory harness to the ballast instead of the stupid things you slide into the factory harness?
-----HID FOG LIGHT BULB UPGRADE SHOPPING LIST-----
(1) HID Kit
This HID kit will include two HID bulbs and two ballasts (ballasts regulate the amount of current flowing to the HID bulbs).
When ordering, you must specify the bulb number, wattage, and color temp:
Bulb Number:
5202, 9009, or H16 are acceptable (all three are physically identical but were designated with different numbers by different agencies)
Wattage: The majority of HID fogs on this forum have been 35 watt. With those, like I said above, it's a toss up. The 55 watt will absolutely melt your fog light housings. Some discovered 25 watt kits while searching online, but there has been debate if they're actually 25 watt or just re-labeled 35 watt kits. Hard to say what's correct.
Color Temp: The actual color of the light, measured in Kelvin. 3500K is stock yellow, 4500K to 5000K is white, and 6000K is white with hints of blue. Color temps of 7000K & above are very blue/purple and are definitely not recommended.
(2) 5202 male / 9006 adapter *optional*
Most HID fog kits only have two bare wires for connecting to the stock source (which sometimes have metal pins on the tips). You can either jam these pins in the factory fog sockets, cut into the factory wiring and splice in the wires, or purchase 5202 adapters off eBay which you can connect to HID kit and then easy snap into the factory connections.
Finally got my 6k HIDs for the headlights installed on Monday.
Know a guy whos been installing in the Dallas area for about 8 years now and it only took him about 20-25 minutes.
Bought some LEDs for the fogs off Ebay and installed those myself about 2 weeks ago. Everything seems to match up well.
SInce my HIDS aren't going to work out and I'm sending them back. Has anyone tried these on the new 2015 Silverado Morimoto XB LED Headlight Bulbs. I figured if I'm returning back to the same place maybe they will exchange and refund the difference but I don't want to go back down the road of getting something that either doesn't fit or isn't trusted.
They are actually taking your kit back? I'm sure they know about the headlight covers, and I'm rather upset they don't mention it on their site. Keep me posted as to what you end up doing.
Oh dont worry there is a catch of course. 20% restocking fee and a 5% fee on any item that is not still in the original package. So bascially by the time i get the refund i will essentially only be getting about 1/2 of the money back. Thats why their was no kickback on the return im sure. But in the end thats better than never using it.
How did some of you mount the ballast for the fog lights?
I picked up DDM's canbus Hid kit over the weekend and took a look at installing it today and found out that they only gave you about a foot a wire to mount the ballast. My plan was to put them all on the extra battery spot in the engine bay, easy access and out of the way.
When i checked there web site they only offer extensions on the amp cored and not the bulb connector.
What kind of wire is normally used on these? could i just cut off the plugs and extended it?
Wow, so much reading. :lol: Just picked up a '15 LTZ and want to upgrade the factory projector low beams to HID. I am not interested in any retrofitting at this time. I want something plug and play and without any drilling or permanent modifications so I can revert back to stock if need be due to warranty.
Is the 35W Silverado Spec: Morimoto Elite HID System still the best setup for me? I'd go with the 5500k bulb.
I'd love to upgrade the fogs as well if there's any feedback on what's the best plug and play option.
Edited by SheeB
Anyone know if these lights internals are identical to OEM? Like the mounts and brackets. Asking because I want LTZ lights and would put in some FX-R's. I would want to use the brackets FASTHeadlights sells. Trying to avoid cutting open a light...and paying $700 for true OEM.
http://www.ebay.com/itm/381077913823
I own the very same ltz replicas and they are very identical. I have disassembled the entire light before and it seems to be the same specs. But if you like just order the replicas and then order the bracket to see if it fits before you buy the entire retrofit kit
There is some drilling involved and the rubber grommet that comes with the kit doesn't really fit because the bulbs stick thru the hole in the cap. At least it did on my 15 LTZ. I didn't realize this until after I had purchased the kit. I just recently returned mine because I'm like you didn't want stray to far from factory just yet considering I just bought the truck.
^^^ Oh, that sucks. Is it only the back cover that gets drilled? I could always get spares of those from the dealer I suppose.
I have a 2014 sierra all terrain with ddm tuning hid kit and for some reason my passenger side doesn't seem as bright, I'm not sure if its the bulb or what but it seems to be pointed off to the side quite a bit, has anyone else ever had this problem?
I tried this a few months ago with not much luck. The projectors in the replicas must have different mounting specs than the projectors in the OEM LTZ headlights. The brackets from fast headlights are designed for the OEM specs. I had the FXR projectors in the replicas, but they were not secure as I wanted them and you have to do some flexing on the mounting kit. I picked up a used driver side OEM LTZ headlight and the kit went in must nicer.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
