Having a bit of trouble with a TRS/Morimoto HID install.
Had a 2014 Sierra SLT that the following system was being used in:
9006: Morimoto Elite HID System
-2 x AMP: Morimoto 3Five DSP
-2 x 9006: 3Five 4300K $0.00
-2 x Canbus: 9006 $0.00
System was removed from the 2014 and placed in a 2015 Sierra SLT today. I can't for the life of me get the lights to work. Fuse looks good and after speaking with TRS I hit my ground contacts with sandpaper to remove some paint and ensure a good connection.
Any ideas? Did anything change from 2014 - 2015 that would prevent the system above from working?
Thanks in advance.
Polarity was switched on the signal from the vehicle to the lights.
All fixed.
-----HID FOG LIGHTS-----
Installing HID fog light bulbs in the 2014's has so far been a mixed bag. Some members have installed operated them for months without incident, while others have had their HIDs melt the fog light housings. It seems to happen across the board and isn't due to one brand running hotter than another. It might possibly be to duration of each use, with some magic number of minutes that, if you exceed, it'll begin melting the plastic. No one has really shown any evidence for why some melt and others don't. So that said, if you choose to install HID fog bulbs, realize it's a toss up on them damaging the housings.[/size
So that's the part that goes from the factory harness to the ballast instead of the stupid things you slide into the factory harness?
-----HID FOG LIGHT BULB UPGRADE SHOPPING LIST-----
(1) HID Kit
This HID kit will include two HID bulbs and two ballasts (ballasts regulate the amount of current flowing to the HID bulbs).
When ordering, you must specify the bulb number, wattage, and color temp:
Bulb Number:
5202, 9009, or H16 are acceptable (all three are physically identical but were designated with different numbers by different agencies)
Wattage: The majority of HID fogs on this forum have been 35 watt. With those, like I said above, it's a toss up. The 55 watt will absolutely melt your fog light housings. Some discovered 25 watt kits while searching online, but there has been debate if they're actually 25 watt or just re-labeled 35 watt kits. Hard to say what's correct.
Color Temp: The actual color of the light, measured in Kelvin. 3500K is stock yellow, 4500K to 5000K is white, and 6000K is white with hints of blue. Color temps of 7000K & above are very blue/purple and are definitely not recommended.
(2) 5202 male / 9006 adapter *optional*
Most HID fog kits only have two bare wires for connecting to the stock source (which sometimes have metal pins on the tips). You can either jam these pins in the factory fog sockets, cut into the factory wiring and splice in the wires, or purchase 5202 adapters off eBay which you can connect to HID kit and then easy snap into the factory connections.
Finally got my 6k HIDs for the headlights installed on Monday.
Know a guy whos been installing in the Dallas area for about 8 years now and it only took him about 20-25 minutes.
Bought some LEDs for the fogs off Ebay and installed those myself about 2 weeks ago. Everything seems to match up well.
SInce my HIDS aren't going to work out and I'm sending them back. Has anyone tried these on the new 2015 Silverado Morimoto XB LED Headlight Bulbs. I figured if I'm returning back to the same place maybe they will exchange and refund the difference but I don't want to go back down the road of getting something that either doesn't fit or isn't trusted.
They are actually taking your kit back? I'm sure they know about the headlight covers, and I'm rather upset they don't mention it on their site. Keep me posted as to what you end up doing.
Oh dont worry there is a catch of course. 20% restocking fee and a 5% fee on any item that is not still in the original package. So bascially by the time i get the refund i will essentially only be getting about 1/2 of the money back. Thats why their was no kickback on the return im sure. But in the end thats better than never using it.
How did some of you mount the ballast for the fog lights?
I picked up DDM's canbus Hid kit over the weekend and took a look at installing it today and found out that they only gave you about a foot a wire to mount the ballast. My plan was to put them all on the extra battery spot in the engine bay, easy access and out of the way.
When i checked there web site they only offer extensions on the amp cored and not the bulb connector.
What kind of wire is normally used on these? could i just cut off the plugs and extended it?
Wow, so much reading. :lol: Just picked up a '15 LTZ and want to upgrade the factory projector low beams to HID. I am not interested in any retrofitting at this time. I want something plug and play and without any drilling or permanent modifications so I can revert back to stock if need be due to warranty.
Is the 35W Silverado Spec: Morimoto Elite HID System still the best setup for me? I'd go with the 5500k bulb.
I'd love to upgrade the fogs as well if there's any feedback on what's the best plug and play option.
Edited by SheeB
Anyone know if these lights internals are identical to OEM? Like the mounts and brackets. Asking because I want LTZ lights and would put in some FX-R's. I would want to use the brackets FASTHeadlights sells. Trying to avoid cutting open a light...and paying $700 for true OEM.
http://www.ebay.com/itm/381077913823
I own the very same ltz replicas and they are very identical. I have disassembled the entire light before and it seems to be the same specs. But if you like just order the replicas and then order the bracket to see if it fits before you buy the entire retrofit kit
There is some drilling involved and the rubber grommet that comes with the kit doesn't really fit because the bulbs stick thru the hole in the cap. At least it did on my 15 LTZ. I didn't realize this until after I had purchased the kit. I just recently returned mine because I'm like you didn't want stray to far from factory just yet considering I just bought the truck.
^^^ Oh, that sucks. Is it only the back cover that gets drilled? I could always get spares of those from the dealer I suppose.
I have a 2014 sierra all terrain with ddm tuning hid kit and for some reason my passenger side doesn't seem as bright, I'm not sure if its the bulb or what but it seems to be pointed off to the side quite a bit, has anyone else ever had this problem?
I tried this a few months ago with not much luck. The projectors in the replicas must have different mounting specs than the projectors in the OEM LTZ headlights. The brackets from fast headlights are designed for the OEM specs. I had the FXR projectors in the replicas, but they were not secure as I wanted them and you have to do some flexing on the mounting kit. I picked up a used driver side OEM LTZ headlight and the kit went in must nicer.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
