3 hours ago, FastWS6TA said:
Hey there. In am still working on the brackets to try and move them forward some. But as far as the dust cap goes, did you take the threaded shaft off of the back of the projector? It should be fit easily with that removed.
Sent from my SM-N920V using Tapatalk
Yes I had removed it. The cap was rubbing against the sides of the projector base itself (the cast aluminum fan guard/cooling fins piece). It may be because the aftermarket caps are slightly narrower than stock, I'm not sure. Moving the whole mled projector forward should resolve that issue however. I could trim down the projector mounting pegs in the headlight itself, just don't have the nerve to break out the Dremel yet lol
On 12/17/2017 at 1:00 PM, skreechyca said:
Finally did a fxr retrofit on a 2015 Silverado with factory projectors. Light output is amazing. Used the d2h bulbs and everything did fit under the cap.  It appears I am having issues with my cut off line. It looks as if one side is shadowing the other. The step isn't even, like there are 2 steps side by side instead of 1 distinct step in the middle. Tried taking pics but they don't show the 2 steps. Looks perfect in the pic. Lol  Any idea welcome. Thanks.
were you able to get this adjusted?  I just put in g5-r projectors (knock off morimoto d2s 4.0) and i feel something is off onthe step too.  Both lights seem to be every so slightly tilting up tot the right.  not sure how to readjust as i use the CDB brackets.
I had used the bottom brackets.  I put a small washer on the bottom of the bottom 2 bolts as they would just eventually turn without tightening and I noticed they weren't overly tight and not quite the same amount of threads on showing.  I wasn't able to use the top brackets but pulled the screws out as it was forcing them in different directions.  That seemed to do the trick.  Even with the D2H bulbs I think when it warms up I will pull the caps off, heat and stretch them as I feel they should be pointed up higher, but the adjuster is getting pretty tight.  It is on a 3/4 ton so they do sit ass up compared to a half ton.
I used FXR projectors, morimoto 55watt 5500k.  The light output is insane!!!  So bright and so wide.  My wife has a 2017 MDX and I thought her  headlights were amazing, not anymore!!!
On 10/27/2017 at 8:13 PM, FastWS6TA said:
Should have the Morimoto M LED projectors and brackets available in a week. Easy install. No wire harness. No dust cap modification. All wiring fits inside the headlight so no grommets needed either. Smaller than FXR so it goes in easier. Fxr is still the better performer but requires more for the install.
This will be available for the Sierra and Silverado. Although I would still recommended the FXR for the Sierra. Since the Sierra requires to open the back of the headlight it doesn't matter that the MLed is smaller. My other concern with the Sierra retrofit is that if the MLed project has an issue it means the whole thing needs to be removed. That would require the back or the lense to be removed again. The FXR projector doesn't fail, but if a bulb or ballast did it is an easy swap.
Hope that all makes sense. Lol.6c4b5c20ce02d1604fe09938c26ad577.jpg58eaaab481492d8fc10c1f061b76fd9d.jpg
I don't see this listed on your site. I emailed about having to take the lense off for the FX-r last week and was set on that until I found this post on the forum. Am I not looking in the correct spot on your website?
Still don't have them in the site yet. Having an issue with the lenses not being far enough forward in the housing as compared for the FXR. This results in an more narrow beam pattern. You might want to grab the FXR kit as it is the only option for a little while longer.
looking for a larger dusk cap for 2015 Chevy  Silverado ??? ANY Information will be helpful. Thanks
Thanks for the reply. I can wait as I just picked up a set of oem ltz lights for $200 and it's waaaay too cold to install aka I dont want to start the heater and have to pull them back out again to swap to what i feel is a more reliable setup *LED over HID.
I’ve emailed the retrofit source (TRS) with an on going HID issue and have not heard back in 3 days. Any one on here work for them that can help me out?
Replaced what was left of the plastic FXR brackets with aluminum version. Replace reflector and dropped down to 35 watts.
Hey man. Who made the aluminum ones?
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
