What's up gentlemen!!! Sooo happy to be apart of the club now! Just traded in my pos bmw x5 for a beautiful 2014 chevrolet silverado LTZ! Damn I love it! BUT like everyone here, hate the headlights lol I've been doing a ton of research and read so many pages here...
One thing I have not seen much of is buying entire aftermarket headlight assemblies with halo style DRLs, so pretty and sexy, with pre-assembled HIDs. Example here..
https://www.protuninglab.com/hidxe14chsio1.html
This is in the description :
Most online seller also offers aftermarket headlights with HID kit. However, they do not offer pre-install HID combo because most headlights will require minor adjustment in order to fit HID light bulbs. At ProTuningLab, we offer pre-installed HID kit with the projector headlights. We will install the HID light bulb with the headlights and connect all wiring needed along with the HID ballast. When you receive the package, you simply install the headlights as instructed without worrying how to install or make adjustment with the HID system.
I'm thinking of buying those (Spyder manufacturer) or one of the other headlight kits (really like this spec-d one below too).
https://www.protuninglab.com/hidxe14chsi11.html
I know about the retrofit source and their entire HID Kit for like $200 I think? Then the same headlights I'm looking at are $350-$400 by themselves, so to me it makes sense to buy the pre-assembled one for around $400. Yes you have to buy the relay harness ($20) and maybe canbus?
I'm looking to not only get HIDs but also replace the entire headlight assembly the includes some type of u-bar (halo-ish?) DRLs.
Would love anyones opinion on this! And like I said, happy to be in the Chevy Silverado club!
I drew them up in solid works and my cousin machined them for me.
Lol. Ahhh okay. Because I was going to be like dang I think someone 3d scanned my design and was reselling it. Lol. Although I figured if someone wanted to go through the hassle of machining them on a cnc they could have at it. Lol. I machined mine in my cnc one time and that was enough for me.
Sent from my SM-N950U using Tapatalk
Not going to sell them, just wanted to never worry about that part again. First time drawing parts 8n solid works also, so things for me will get way more attention. It would be great to make things to sell, but for now any practice I can find.
I just spoke with Phil from fast headlights on the phone. I had no idea the projector retrofits actually come with the bulbs and ballasts.
Only $350 - 10% for forum members and you get an easy to install d2s 4.0 projector, ballasts, and bulbs.
All this time I thought you needed to buy the projector retrofit and then you buy the bulbs and ballast. I mean it’s $180 for the morimoto hid kit. For only $135 more you get a projector upgrade and hid kit.
Only $315 to have top of the line headlight output and beam pattern. That’s definitely a no brainer.
  • Thanks 1
I just want to put this out there for reference, because if you're like me you're always interested in spending more money up front on a quality product than to have issues later down the road. I will be going with the morimoto 4.0 setup from fastheadlights, but here are two videos that really show the quality and the differences for these and the rx350's which are considered some of the best retrofit projectors on the market. I think the pattern on the 4.0 is nicer and wider for me, and subsequent I will get going that route. Also, they are much cheaper.
Also, phil, any issues with the thread-mounting mentioned in the second video? I assume we have a higher install height and plenty of adjustment. Just asking the pro!. Thanks
Installed on a tundra for reference... Man they are pretty!
Edited by SWOYER
Looks like I’m gonna try these in my Anzo head lights and go from there. They seem alright. I have the H1 bulbs in the Anzos so that’s why I’m trying these.
https://www.amazon.com/gp/aw/d/B00J2CHZF0/ref=mp_s_a_1_1?ie=UTF8&qid=1518449357&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=H1+opt7+led+show+glow&dpPl=1&dpID=51g7zV7mY0L&ref=plSrch
I just did my retrofit yesterday, and wow what a difference!
I used the FastHeadlights 2014-17 GMC Sierra Morimoto Mini D2S 4.0 Kit with Hylux Ballasts. 5000k Bulbs. 35w Ballasts.
http://www.fastheadlights.com/ProductDetails.asp?ProductCode=buy_d2s4_sierra_kit_hylux
Here is what I learned and advise based on my own experience.
1. Allocate about 8 hours to do this, it might not take you that long but it could. If you are taking your time or run into the smallest of hiccups, you will use a lot of time.
2. Upper bumper removal (plastic). Take your time! Don't go yanking on it.. Work it from the outsides and top to get the outsides loose, do both sides, then when your releasing the tabs from under the bumper have someone else hold it and guide it out slowly. I broke two black tabs off, one on each side.. I don't know where they were but when I reinstalled it there is a small gap between the fender, this piece and the headlight, It's not totally noticeable but I assume that's where it was.
3. The fastheadlight kit brackets are very nice and bolted right up, but I found that in my particular instance one of the projectors was a tight fit matching up to the headlight via the bracket holes. I've narrowed down the possible causes to the following; 1. The screws need to go in perfectly straight, if you are off angle at all then you will exaggerate any misalignment issues with the projector mount. 2. I used the next size up drill bit on the holes to open up the holes slightly, the threads still grabbed even though they don't need to. But, I believe this helped ease the installation even if it was just mental.
4. The plugs that are on the harness from morimoto are too wide to fit into their own provided connector let alone the harness for the headlight. You can either shave them down to fit, or cut them off and put smaller ones on. I cut them off, threw out the loose packed adapter and plugged directly into the headlight harness and wrapped everything up tight with electrical tape. I was worried if that connection ever came loose I would have to pull the bumper and everything again, but the wiring is loose in the headlight housing and there is enough slack that I can pull it out the back and set/tape them if they ever work loose. But I doubt they will.
5. Pulling the bumper, grill and lights looks terrifying, but it's really not that bad. Now that I've done it once I feel like I could easily do it again. Take your time and follow the guide and your fine.
6. The hylux ballasts are cheaper than the morimoto, but, that doesn't mean there is any less quality. I found that the ballast performs well, it does have a slight buzz to it, but heat up time is acceptable. It's not the fastest, but it's not bad either. This is the amount of time it takes to reach full power from when the light is turned on. If you have the chance, you should consider the 45w version over the 35w. The 35w is very bright, but its not the same as a 55w. And while the 55w is very very bright, I think the 45w might be a good sweet spot.
7. When cutting open the backs of the headlight housing, you may be tempted to use a dremel. Per the recommendation from fastheadlights, I found that using a box cutter heated with a torch to be far more effective and it didn't blow all kinds of debris into my headlight housing. BE CAREFUL OF THE WIRES INSIDE when your cutting, both the headlight harness and the shutter wires are close, but you can reach in and pull them away with one hand while you cut with the other. You hit those wires and you're going to create a lot more work for yourself. Also, use a junk knife, heating it with a torch will ruin it.
All in all, I am very happy with the install and the ease this retrofit provides as compared to others I have done in the past. The GMC headlights are very easy to work with and the end result is amazing compared to the junk stock setup. If you are worried if you can do it, take your time, do your research and you'll be fine. Just give yourself enough time.
Big thanks to FASTHEADLIGHTS for the customer support and for figuring this stuff out in advance.
Will post pics of the process tonight when I adjust the headlights. (also very easy)
swoyer and I pretty much did it at the same time and we were messaging back and forth
As someone thats never done it before, it was quite a bit more difficult than I expected. Initially I was not pleased I took that path.
In the end, it obviously worked out and the headlights look amazing.
It is indeed a solid 7 hours if you’re taking your time trying to do it right. If I had to do it a second time, I could probably do it in 3-4 hours, but that’s still quite a bit of work.
The good news is, that unlike most jobs working on cars, a lot of the time is spent on the work bench. Which is obviously far easier than turning wrenches on your back and the 7 hours is mostly enjoyable.
I’d probably do it again knowing how much work it was. I can understand why a custom shop would charge several hundred in labor.
Phil from fastheadlights said it would be easy lol, I guess some people have different ideas of easy.
I do have to say, if you are going to buy a retrofit, it’s pretty much impossible to beat the customer service at fastheadlights. I was literally texting Phil at 8pm asking questions and he said multiple times “don’t hesitate to ask me anything”
and yeah, I’m like $315 all in and my headlights are incredible
Here's some photos I snapped.
Do they look slightly wide to anyone else? The left headlight kind of trails off before the right projector overlaps. Maybe that's how it is supposed to be?
Also got a bunch of dust in there I guess from working in the old man's shop. Now I guess it's just stuck in there lol? 4f848b0dd69dcc181312f49b1c2e3b07.jpg5cc5a89b069cf12222714f0e739f9a8a.jpg23daada082573508987a979edb01e85b.jpga30b9157e123c8a61c40fa810438f873.jpgc659c73731fe8f56f22aa76c474d2727.jpgf052c53f2615842a244e022e7b985336.jpge2438813bebf1000dc0687efdaf842ad.jpg5b37723c09c798b470e02d1a1a628cc4.jpgd5242ea8e192a411c42abd4875422db6.jpg29dea014fcd1e8222108e4c3e515c955.jpgbf94ae0f489006fbcf922bfc85855b48.jpg
Sent from my SM-N950U1 using Tapatalk
Anyone need a set of the FAST Headlight adpaters for the FXR projectors? I didn't want to pull my lights a part more than once, so I bought another set to model the aluminum ones I made and now I have no use for them. I miss placed one set of the bolts for it, but if your like me they get replaced by stainless steel anyways.
I have dust too, wish I had bought some canned air or turned on the compressor. I just wanted to get it done so I’m like screw it.
beam pattern looks great IMO
Sent you a pm
ok good. It's weird because depending on where the headlights are hitting those cutoffs are like straight, angled, makes your head go loopy trying to make sure if you did it right lol. Also, I'd say the pics are a little brighter than real life, camera must have adjusted. Thats more what a 55w ballast probably looks like. But still bright.
You replaced your entire stock headlights with the Anzos?? That's the route I'm thinking of going. Do you have pictures? You like them? I just feel if I'm gunna take the time to do HIDs I might as well replace the headlights since I absolutely love the halo/U-bar style daytime running light look.
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
