YQatari do you have any pics? Would love to see them. As for mod the speedometer I hadn't put much thought into that yet. Would hate to void the power train warranty... As for LT vs P? I have no idea what that is
Speedometer will be off a little bit with 275/60R20, about 1.5-2%, no big deal.
Here are a few pics taken with my phone.
For the same reason I did a 1.5" leveling kit on my truck and leaves the rear .5 to .75 higher. I still clear 285/70/17 tires with no problem.
Anyone running a 1 inch leveling kit? Looking for pics or reasons not to. 2 inch was too level for my use.
One reason I haven't done it yet is because I don't want to void the warranty.. and I've heard on here that any suspension mods will void warranty for suspension.
The only component you might have to worry about them not honoring the warranty for is the ball joints.
When my old GMT-900's went out at 25K, my dealer changed them under warranty despite the truck having a leveling kit.
Did a 2" leveling kit yesterday. Here is before and after with stock tires & wheels. New ones on order.
Before:
After:
Before
After: 2.5" RC Lift and 285/60/20 Goodyear Duratracs
I went with a 2" level because I had heard some stories/rumors that a 2.5" can mess something up with electrical or something along those lines. How true it is - I do not know. The 2" looks level to me, getting some new tires put on today, I'll post some new pics later today.
I went with a 2" level because I had heard some stories/rumors that a 2.5" can mess something up with electrical or something along those lines. How true it is - I do not know. The 2" looks level to me, getting some new tires put on today, I'll post some new pics later today. Sent from my iPhone using Tapatalk
Have the 2.5" on mine now for two months and have had no problems at all.
For those that have installed a 2 inch front level kit on their Sierra or Silverado, what's the largest tire you've put on without rubbing? I want to put 33's or a little more on my Sierra.
33's on mine, not an issue at all. Looks like I could clear a little more than that. Agreed with above, have seen some with 35's but that might be the 2.5" kit.
All done with tires. 275/70/18 Nitto Terra Grapplers.
(Window tint later today)
(Stock):
(2" Leveling Kit):
