The tires you have are LT tires so they are most likely a 10 ply. That is what is holding me up right now on buying what would be my 3rd set of tires. I want to get at least a 33" tall set of tire, closer to 34 would be perfect for me but I haven't found any "P" series tires that would get my that height. I don't want or need the 10 ply or want the heavy weight of the LT tires.
NoTyme - Nitto makes a 305-55-20XL Terra Grappler which are 33.2" tall and 12.4" wide and are extra load 4ply tire and not an LT 10 ply. These weigh in at 49lbs. Pretty happy medium, and I think this will be my next set of tires.
Thanks for the tip. I may have to look at them and see if they will fit with my stock rims.. :thumbs:
These Terra Grapplers are just shy of 32.5. I'm happy.
I know you guys get this questions all the time but I have a 2014 1500 z71 I have a 2.25 ready lift done. I'm looking to put the toyos mts on 275 70 18 on my stock rim. It measures a 33.6 I'm worried that I'll rub a lot I don't mind cutting a little but don't want to tear anything up thank you.
I have the toyos on mine in have a zero offset though and a 4 in lift just rubs the inner fender liner when doing a sharp turn I'm not sure they will fit with out an offset
what size tires do you have??
275 70 18 on a 18 x 9 worx rims with plus 0 offset it just rubs on the inner "carpet" fender liner when backing up or super sharp turn
If I'm sitting at 36.5" in the front and 39.5 or 39.7 in the back would the RC 2.5 front level only put the front higher than the rear? Should just 39 in the front and 39.5 in the back.
For those running 2.5" front level only how was your gas mileage?
Edited by 5RWill
I installed the ReadyLift 2.25" Leveling kit and I couldn't be happier. The overall ride quality doesn't feel any different than factory, the company was great to deal with and the build quality of the parts were awesome. I'm going to start with a set of 33" Terra Grapplers but if I feel the need for more tire and a larger lift I'll be calling them for the next kit as well.
What was your height of the front and rear fenders before?
Never measured before, but I'll take a measurement later
My kit has only been on two days. I did a 2.5 and a 1 in the back.
Truck sits great. I have not seen a change in gas millage. Stock wheels and tires.
I'm sure my new tires will kill the millage, but there a week out.
Mine was the exact same measurement as yours before I installed the 2.5 RC kit. I DID NOT put on the rear block and my measurements after the lift was installed is 39.2 in the front and 39.5 in the rear. I personally love the way it looks. I've been riding with the stock tires now for about 5,000 miles and am getting about 18mph average. I also took off the front air dam, so that may have affected my gas mileage as well.
fuse36, on 26 Dec 2014 - 11:24 AM, said:
I had the same set up. Switched to rancho quicklift loaded and rides awesome now. It's a complete strut replacement with a little over 2" of lift
Sent from my iPhone 6
using Tapatalk
Hey thank you. I just checked them out. did you do anything to the back? im going this route for sure. I cant stand the ride.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
    • 1Based on independent testing of OE 0W-20 in the Peugeot TU3M Wear Test as required by the dexos1 Gen 2 specification.
