I ordered a pair of 5100's this afternoon. Can't wait until they get here!
Now time to do some tire shopping!
2" Rough Country - 275/65r20 BFG AT K02
23570646493_d39a6b2837_z.jpgUntitled by Dustin Wince, on Flickr
23829643149_cd06c9cd7f_z.jpgUntitled by Dustin Wince, on Flickr
Truck looks great... This is the look i am gonna go for.. But I'm thinking really hard about doing the bilstein's 5100 instead.. But hope to get the same look with the same tires.. With your setup do you think the Weathertech no drill mud flaps will still be able to be used when turning front tires?
Again nice looking truck!!
Edited by white2015sierra
Truck looks great... This is the look i am gonna go for.. But I'm thinking really hard about doing the bilstein's 5100 instead.. But hope to get the same look with the same tires.. With your setup do you think the Weathertech no drill mudflaps will still be able to be used when turning front tires?
Tim
Thanks! I haven't seen what they look like inside the wheel well, but I can only imagine it would make things very close when its already a close call as is.
Edited by dkwince
Just got my lift done two days ago and wheels and tires done yesterday. 2016 All Terrain. Readylift 2.25" with Method NV 17x8.5 0 offset wrapped in 285/70/17 Duratracs. No rub. Rear mud flaps, Go Rhino RB10s, and GM/Borla exhaust are ordered. Quick cell phone pics...
  • Like 5
So is the Suspensionmaxx kit the only leveling option currently MADE for the Denali's with magnetic ride? I know some mentioning Motofab, etc but these are kits where the shop moves around the sensor's themselves.
Do you think the 285s or 295s on stock rims would fit width wise without rubbing on a RC 2.5 level?
I would think so. Initially, I had just a 2" level with 305s and the slightest rub at full lock in reverse. Of course it depends on how tall you go as well.
I'm going with Bilstein 5100's here in the next week or so. I want to put them on their highest setting for the most amount of lift in the front. How will my ride quality compare to stock if they are at the max setting?
From what I have read ride quality will be nice but just a bit stiffer. I'm putting on the RC 2 inch this weekend and if I do not like the look of it (nose high) I will be getting the 5100's.
So...what's the verdict then on leveling kits with magnetic suspension on my 2016 Denali? Do I need a specific kit? I know I want a 2" level, but no clue what route to go on manufacturer. Help!
God i love methods looks phenomenal
I just put the Bilstein 5100s set at the highest level on my truck. Its still a bit taller in the rear but a much better stance than stock. Soon to have 285/70r17 bfg a/t ko2s pending funds.
Edited by quail hound
I have a 2.5in leveling kit here that I was going to install, but I decided to not get bigger tires.
I think the 2.5" on stock tires will look stupid, so I think a 2" level is the way to go for me on stock tire size...
My buddy just had a level kit installed that was the top strut version. His guy said it had better ride quality than the lower strut block I'm doing.
Is that true? Am I sacrificing for a super rough ride?
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,303 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
