Just picked up my 2016 GMC Sierra from the shop today. 2 in RC level and 285 55 20 Hankook Dynapro's 10 plys. I'm going to be posting more pics under the thread I started as well as any changes I've noticed and MPG changes after I run a couple tanks of fuel through it. 20% tint on just front windows. More info in bottom link. I will try to get up more pics in the thread below asap!
http://www.gm-trucks.com/forums/topic/181879-my-new-2016-gmc-sierra-ccsb-z71-slt/
Here's a before
And after.. More pics to come
Yes, it changes quite a bit actually. Any time you do suspension mods, even just strut replacement an alignment is recommended.
This is very true. Just remember that the upper and lower control arms are different lengths, so as they move up and down together, the camber is changing continuously. If you change the static ride height, you are also changing the static camber setting, which you want to be pretty much zero or close to it. Otherwise, you'll be continuously wearing the inside or outside edge of your tires as you roll down the road.
I had an issue with 4 Wheel Parts. I ordered TA KO2 on 12/30, got told I'd see them end of next month, today.
I called Discount Tire who had 4 in stock, they matched my price and I picked them up tonight. I hope to install level soon and the tires.
LT275/70R18
Sounds like you'll have a good looking setup! I think mine is very similar to what you're looking to do. I have the same tires and a 2" level on mine. Black truck too.
2.5" Level kit with 1.5" body lift. 305/55/20 Nittos
Edited by rhino2020
Looks great... did you need BL to fit the 305/55 ?
I don't think it was a have to have but I like the look. I don't have any rubbing issues. If I didn't have the body lift, I would've had to pull the liners back a little.
There is no actual harm installing my level kit and then getting tires installed and alignment done week later, right? I'd be driving around on the stock tires which I don't care if they wear differently. Just trying to work my schedule and it looks like I will only be able to do lift install one day and tires a week later.
Honesty it depends on the wheels. I have a 2" level on 305/55 on the stock silverado 20s and it rubs just a touch at full lock
I have +18mm offset wheels.
You should be good for a week. My pulled bad to the left after the level kit was installed.
Agreed. Shouldnt be too bad. I was lucky and was able to get mine in within a day or two for an alignment.
Some (somewhat) cleaned up pics with my 2.25" readylift level and 2" rear block.
Sold the dropstars and 33s and will be buying a new winter setup. These 22's will be my summer wheels.
20160115 135415 1 1
20160115 141120 1
20160115 141137 1
Edited by buckeye6
And this is the solid chevy grill I am talking about ae0c4354422e358005fa1035b68f019c.jpg
Who's 16' serria and what set up is that? That's exactly what set up I want. Sweet truck
bcbz71, on 13 Jan 2016 - 3:37 PM, said:
I put the 2.5" Rancho ReadyLift on my F150. It was a horrible ride just like you are talking about. I put the 2.5 Level on my '14 Sierra and it's much better than my Ford with the ReadyLift. I would just suck it up and get rid of that lift and go to a leveling kit. Lift is too short to ride in a truck like that.
First of all, yes, your dealer can align it; they are choosing not to. Having a crooked steering wheel would drive me nuts.
Wheel alignment is a crap shoot. I went to one of our better known 4x4 places after I put my level on and they brought it into "green" specs. Only the Toe was out. But it was wearing the LF tire bad, so I took it back and they said it was a degree off. Still noticed wear on LF, so at 15K service at dealer today, I had FE alignment done. Their print out said the LF was fine but the RF was off. ?? That makes no sense to me as the RF was not wearing. I had an X rotation done, so I'll monitor treadwear and see what happens. At this rate, there is no way I'm get 65K out of my Nittos.
Thanks for the help. Yah its pretty crappy. I will probably be going that route sooner then later as I just cant stand it. I also got back from the dealer yesterday and they said they would align for me. and fix the steering wheel but nope. what is it they need to adjust to fix that? driving on the hwy with a slightly crooked steering wheel does drive you nuts. I cant believe they said they fixed it but thats what you get.I paid them to do it last time so im not expecting a hand out to a suspension mod either just to try and get it back to normal. Its just a "level" kit I didn't expect this many issues with it. makes you regret it that's for sure.
can any one recommend a better option upfront?
also, I currently don't have stock coils as when I swapped them out I had them in the back of my truck and they actually went missing if you can believe that. so I would have to grab new ones :(
Take out the ReadyLift struts (and sell them) and put your original struts back in. Get a RC 2.5 level kit with rear blocks and install it. Maintains close to your factory ride with just a little loss in suspension travel. Get a FE alignment and you are ready to roll. Any shop that does your FE alignment can fix your steering wheel....it's part of an alignment package and I wouldn't leave or pay until the wheel is perfectly straight.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
