I was wondering if you can install the ProComp kit with just the top spacer? And if so around how much lift that would provide?
Yes. That is exactly what their 1.5" level is, just the upper spacer. Brought mine up around 1.75".
I asked this previously but no one really replied.
Whats the difference between these lift kits besides brand and price difference.
RC is around $50 for just a 2" level but pro comp and blistein are $150+?
***(before i get some smart ass answer, this is a genuine question as i know absolutely nothing about these companies & products, what they offer/do besides "level & lift)
Galaxy Note 4 Using Tapatalk
Thanks! I bought the kit from someone who never installed it but really wasn't looking for the full 2.5".
RC is a small resin "clip" spacer installed on the bottom of the strut. The cheaper levels are usually this type but aluminum.
Pro Comp and Readylift are billet spacer rings that mount on top of the strut.
Bilsteins are a whole new strut with adjust-ability of height.
Thank you very much
Edited by quise2024
Did you go online and look at the difference? There are different leveling kits from each company. Pro comp has both aluminum and poly and it looks like they just make a spacer for the top of the strut. RC is a poly spacer for the bottom of the strut, but they also make a full 2.5 level kit that has a bottom poly spacer, a top poly spacer, and a new block and rear Ubolts for $150. There are also 3.5 levels that include UCAs and drop kits for your differential.
Any of them will work but if you are just looking for a 2" level, don't be fooled into thinking a $150 piece of aluminum at the top of your strut is any better than a $50 piece of poly for the bottom of your strut. There are thousands of trucks running both and I have not heard of a single failure of the bottom poly spacer.
For anyone that's interested I installed Fox 2.0 Coilovers up front at the factory set position (about 20 threads up from the bottom/ see photo)
With factory steel suspension and LT285/70R17 BFGoodrich KO2s tires (at 38PSI), the distance between ground and fender is approximately 39.75"(after driving about 500 miles).
Here's a couple photos showing the angles:
My next step is to install the Cognito UCAs sometime in the next couple of weeks once they come in.
2WD Z71?
Last night I installed the Rough Country 2.5" lift on the front only and today put the MM 20x9 -12 with 305/50/20 Zeon LTZ on and could not be happier the the look or the ride
Perfect example of why these trucks need rear blocks or air bags when you level them. Put a little weight in the back and they squat and point the headlights to the stars.
Air bags this week!!
I love the look of my 2.5" RC level kit. Installed about 7500 miles ago. Had factory 18" wheels on truck until yesterday. Took truck down to tire shop to get new 20" wheels and tires installed. They informed me that my upper balls joints had some play in them, Truck only has 20,000 miles and level was done at 14,000. Not very happy about that, I think my next step is to go with a different lift. The level kits just cause too much wear and tear and in my opinion do not ride very well. Would like the Bilstein struts 5100's I think..? but not sure if I can get as much lift out of it...? I love the stance of truck now and don't want it too high or any lower. Went with BF Goodrich KO2 275/60/20 on a set of Fuel Vapor Machined 20x9 rims with 24mm offset. Looks great and no rubbing.
Just upgrading shocks(going to 5100s for lift purposes) will put the same strain on the exact parts the level did. You are altering driving and cv angles, consider going with a kit that corrects driving angles and lessens the strain on tie rods/ball joints. It's worth the investment if you have to put a $500+ ball joint and labor in the truck every 5-10k. I believe there are 3" lifts out there which would yield you around the same stance as you currently have.
Edited by tanner709
This sounds crazy, ball joints worn out in 6k miles. Id get another opinon or check them yourself before you worry too much about it.
It does sound crazy. I walked to the rack and physically watched them wiggle the tire from top to bottom. The play is not terribly bad yet or dangerous as the mechanic said, but just wanted me to be aware as I just invested $1300 in tires and could potentially cause tire wear down the road as it gets worse.
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
