18" problems haha I read that 295/70/18 rub with RC 2.5" on stock rims. I love the Z71 rims do i went with the safe bet 275/70/18 Cooper Discoverer. Love em
ImageUploadedByTapatalk1422328467.620829.jpg[/quote
Any more pics? I was thinking of going with the same size with the coopers or the KO 2
Just installed the MotoFab 1.5" leveling kit on mine. First side took me 2 hours, 2nd side took 30 minutes. Glad I did it. Closer to level, but I don't mind a little rake. Rear is 39.25". Front measurements below, and side view w/ the 1.5" kit installed.
Hi guys, I'm new to the site. I have a 2014 Silverado Z71. I had the chrome 20's but traded with my boss for his Tahoe gunmetal 18's. My father in-law lifted his Silverado and is giving me his tires 295/65/r18. He had a 3.5" lift and upgraded to a 7.5" lift. All i want is to level my truck but i am not sure if these tires will have any issues with a leveling kit. Is anyone running these size tires on a stock 18's with a 2" or 2.5" level kit. If so what leveling kit are you using? what brand? Thanks,
With either leveling kit you may have to trim the felt liner a bit as those tires are pretty wide.
I ran 285/65/18's on stock 18" wheels with a 2" level with no issues though. So you may be fine without needing to trim the liner.
I would suggest going with the taller of the 2... go with the 2.5". That's just my 2 cents though.
Thanks,
Would .25" wheel spacer help this issue? also does the leveling kit affect the CV angels? what brand of leveling kit do people recommend? readylift, bds, rough country?
Edited by pepsipopper2001
Thanks,
It might help, but i can't say for sure, as i've never tried it. And with the leveling kit, it doesn't take the angles to the extreme that would cause any significant wear to them. They may wear out faster than in stock formation, but I had my dealer install mine, so it's warrantied.
Any of those brands you named will be great. I use rough country because it's affordable and works well. The others are great too though.
Rough country 2.5 level on 33x12.5x22 Toyo M/T's
How is everybody's trucks riding with the 2.5" rough country kit? I had the 2" level on my truck(14 silverado) and it never drove straight after. Always had a pull to the left and this is after 2 alignments from the dealership! I am in a 16 Sierra now.
Edited by skennel23
I've had my 2" level on my 2015 crew cab for 3,000 miles now with no pulling or change in ride. Thing is perfect!! I kinda regret not getting the 2.5" now lol
So, I have a 2.25" spacer that I have yet to put in. My question is to the guys that have 2-2.5"... Are you guys running rear blocks with that spacer? and if not, is the front sitting higher than the rear or is it sitting level? my fear Is that I'm going to be too high on the front... Thoughts?
I have the RC 2" level block under the strut. I still have a tad bit of rake and am thinking about adding the 1/2" spacer on top. I'm still running the factory block in the rear.
Edited by 8ty8 ls1
I'm running the MotoFab 1.5" leveling kit. That's it, nothing else. Front is 1" lower than the rear, which is exactly what I wanted. Just a slight bit of rake. Made a big difference in the look of the truck, that and removing the air dam.
Sent from my XT1254 using Tapatalk
I have the 2.5" in front and stock in rear. I sit 1" high in front. If you don't tow a trailer, this may work for you. I'm running 305 55 20. Rides good. I'm going to add the rear block to bring it level for when I tow, I won't be so nose high.
Has anyone had problems with the RC 2" front level (lower) block? I went to a 4x4 shop and the salesman was telling "sorry about your luck". "Who installed it?" I told him I did and then he had the balls to recommend that he take look at it to make sure it's correct.
This is pretty good info, thanks, so... of the two of you, one with 2" with still a little rake, and one with 2.5" and a little nose high, I'm pretty sure I should be good right in the middle with my 2.25" installed. Going to run 275/60R20 Toyo Open Country AT2's come next spring. Thanks for the feedback!
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 803 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
