Will a rough County 2.5 leveling kit allow for a 275 70 18 tire without rubbing?
Yes, that's a 33" tire. Should fit without an issue. However, it will throw off your speedometer by about 2mph.
Yessir ill shoot you some pictures. I am ordering them today from Amazon.
I just got these today 2" rear blocks. I'll post pics when on.
Here are some pics of my new ride, just purchased before new year...
2017 GMC Sierra 1500 Denali Ultimate 6.2L 4x4
Mods:
- RC 2" front leveling kit
- AMP Research Power Steps
- GM 4x4 decals added to front fenders (deleted by default on the Denali)
- 35% Window Tint on front windows
- Chrome tailgate lever
- Interior piping added to door panels (75 cent mod)
IMG 0554
IMG 0555
IMG 0556
IMG 0557
IMG 0559
IMG 0560
IMG 0561
IMG 0562
IMG 0563
IMG 0564
IMG 0565
IMG 0566
Edited by Matt_UKTX
So suspension had settled in after 1.5" rear blocks and i was still not content at only 1/2" rake. I upgraded this morning to the 2" rear blocks posted above and now have a 1" rake plus these are steel and the tampered style thats slightly shorter on the front. I am really happy with the results as I should no longer notice a squatting appearance when fuel tank is full. Also while removing the tire i broke the lug nut lock on one of the wheels as i had tighten it too much previously. Lesson learned. Jb weld did the trick to remove it and now need to order a new lug nut key.67a6f9b9a243661fb595fa3f01e3abee.jpgaf32cb0f1625a3762f9e32f8fb42b446.jpg0c001e7526777cbc7c100daf3a206ac5.jpgdd71641f87450ea9a038351ce8082f9f.jpg
Did you have to remove he wheels to put the blocks in? My blocks should be here Friday, so there going in next weekend ( single digit temps in Michigan ) . Truck looks great, I'm really considering removing the side steps, looks a lot cleaner with out them, Are they a pain to remove???
Yes i worked on one side at a time. Jacked up from side and placed on jack stand. Then moved my jack to the center of differential and jack up diff to remove wheel. Unbolted strut from bottom, then u bolts and lower jack slowly. Swapped in the new block and jack back up. Push the differential to align holes while lift jack and bamm all set. Oh and my truck already came without side steps but i do want to install some nfabs because Iam afraid the leather will start to tear and wife and I are planning on another addition to the family so they will be needed.
Edited by asalinasz39
Here's a before and after of a 2.5" RC front & 2" rear block on my '16 Sierra with factory 20's.
Below is a pic of my suspension and the angle of my front drive shaft at the wheel. Love the look of the raised truck, but the ride, its another question. I read back thru the last 20 pages of this specific forum, and only found one comment about the ride. Mine feels as if there is rolling resistance, as if something is holding it back. Yes, in neutral it rolls as it should but even then or under power, still feels like resistance. It's only been 2 weeks since I completed the DIY project. Any thoughts anyone? Just searching the web, a ricer forum thought someones E-brake cable might be pulling taught. Any help?
You don't have to take off the wheels. Here's a post I made about replacing the blocks a while ago...
You can just jack up rear leaf spring. I installed my rear blocks a couple of weeks ago and it about 20 mins. ON A LEVEL SURFACE. Place a 4x4 block on your jack so you have plenty of lift. Position the block/jack on the front side of the leaf spring directly in front of the factory rear blocks. Don't put pressure on the jack yet. Take off the u bolts. Now jack up the spring enough to remove the factory block and install the new one. Slowly lower the jack. You should notice the rear slightly roll into place. This is why you need a level surface. It helps to have someone else there to watch and make sure everything lines up while you lower the jack. Once it's lowered all the way reinstall the u bolts. Do one side at a time. It's very easy.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Thanks, I was planning on jacking up the truck from the rear diff, and placing the frame on jack stands, then removing lower shock bolt, and four nuts that hold each U bolt ( each side ) then lower the rear diff to remove and reinstall new block, and U bolts.. But I will give your idea a try, just have to picture what your saying in my head..LOL
BTW, congrats on the new baby
My neighbor said he just finished his blocks.. put jacks under frame. Loosened the bolts but left them with a few threads.... deflated his tires until there was enough room to work with. Removed the one side and exchanged the bolts and block... then did the other side. Reinflated enough to get it all back in place. Tightened--->full inflated---> retorqued. He says he was done in 40 minutes with air tools. I'm pretty sure tool was right. But I'm doing mine the first day it's above 60*.
Looks nice Matt. Are your Bridgestones the OEM tires (275/55/20?).
Thanks Rolling Thunder... I get a lot of compliments on the truck. Very happy overall. I came from a BMW X5, and this actually drives and rides better (for me). I don't think I will ever go back to a car/SUV.
Anyway, to answer your question, these are the stock AT tires on the 22-inch wheels. I believe they are 285/45/R22. They ride very nice, look aggressive and are relatively quiet.
So suspension had settled in after 1.5" rear blocks and i was still not content at only 1/2" rake. I upgraded this morning to the 2" rear blocks posted above and now have a 1" rake plus these are steel and the tampered style thats slightly shorter on the front. I am really happy with the results as I should no longer notice a squatting appearance when fuel tank is full. Also while removing the tire i broke the lug nut lock on one of the wheels as i had tighten it too much previously. Lesson learned. Jb weld did the trick to remove it and now need to order a new lug nut key.67a6f9b9a243661fb595fa3f01e3abee.jpgaf32cb0f1625a3762f9e32f8fb42b446.jpg0c001e7526777cbc7c100daf3a206ac5.jpghttp://uploads.tapatalk-cdn.com/20170108/dd71641f87450ea9a038351ce8082f9f.jpg[/img
Looks nice! Looks like the 2" blocks will be perfect!
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
