On 7/14/2019 at 10:31 AM, BKGarrison said:
Just bought this 2018 and put 2" front Motofab lower spacer.
Tires are 275/60/R20 (33")
Love the new look.  Not sure on what to do with the air dam yet.
Nothing on the rear?  Truck looks great!
As for the air dam, if you live in snow country, I would pull it off for sure!
Trucks look like toothless hillbillies with out the air damn. I've never had a problem getting around them.
Hey now. There's people in my neck of the woods that resemble that remark.:D:cool:
.. leveled with Eibach set at third notch.. gained a hair over 2" but hoping it will settle to 1.5" as I tow a camping trailer so I still want a little rake
.. two days of driving and the suspension is still sitting at 2".. but OMG that ride! What a difference from the Ranchos.. now this is the truck that I would've loved to have test driven at the dealer.
Lookie,lookie! Got my whole new suspension kit today. Eibach Pro Truck Lift kit and 2" Motofab rear lift kit. Can't wait to install. Gotta wait for cooler weather. 110° this weekend...YIKES!
do you mind me asking how much they ran you?  I am looking at switching...have been leaning Bilsteins...i assume you got the strut and spring package?
.. my prices are $CDN so if $USD they will be much cheaper. I paid $170ea for the front struts and $139ea for the rear shocks. I did not get the Eibach springs as I did not want to lift it the 2.5" that the springs provide. I bought these back in February and have been running the rears since then but only just installed the fronts last week due to disc/nerve issues with my back. After a week of driving they seem to be holding steady at 2" on the third of four notches. I really love the ride at this setting so I will leave it at 2" and I ordered a 1.25" lift block for the rear to gain some of my rake back for towing.
Finally got some tires on my 18 CC. 275/60/20 BFG ATs
Edited by Dwalla7
The whole kit with springs is $560 shipped from jegs to your door.
thanks...I would just reuse the factory springs...I wonder how much that would help me save...I bet they would be pretty close to Bilstien cost.
.. went to dealership today to have alignment done since the 2" level with Eibach struts as I'm heading out on a 10 000km cross country trip this week (4 provinces and 5 states).. all specs were almost spot on.. toe was only off by a tenth of an inch.
Hello all
I have a 2017 sierra denali ultimate 4x4 with the 22" wheels.
My goal is to get another inch or so of tire sidewall / ride height.
It seems the easiest way to do this is to do a level kit.  Can someone please recommend a kit or parts that I should get to get that done?
.. the 1.25" rear lift kit  I ordered for the truck came today.. went with a company that I thought had a rep for quality - Skyjacker - only to be disappointed when the lift block kit arrived to find a short block that they wanted to be stacked underneath the oem block.. what a load of garbage!.. seems I just wasted my money with this company.. not looking to spit a block and ruin my truck.. especially when towing.
  Can someone please recommend a one piece small lift block of good quality..ie. iron with pinion angle correction?
.. just for anyone concerned about mileage impact from leveling with oem tires..I have put around 500km since level with zero negative impact to my fuel mileage.
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
