I'm amazed how ridiculous is the stock front suspension downtravel on these trucks. I initially measured for reference exactly 1,5" when I had the 3" front spacers installed with RC forged UCAs, difference from hub to fender. This was without the bumpstop rubber, UCA was resting on the chassis. I thought that the quite poor ride quality was due to that.
So I decided to lower the truck to get a bit more downtravel, to 2.25" (readylift). And to my surprise I didn't get that 3/4 inch back in downtravel... No...only a mere 1/5" more ! And the UCA wasn't even touching the bumpstop ! Strut was simply bottomed out...So my 2.4t 20feet long 4x4 truck has hardly 2,4" of downtravel on its front struts. Lol. Even my business car Kia Sportage has more wheel travel...This is maybe explained by the so stiff springs they have. They hardly compress when jacking down. Then  I did put back the rubber bumpstops but these are only slightly in contact with the UCAs. So with a 2 inch level kit on stock UCA I guess that full downtravel is still almost here, that's why ride quality isn't too much impacted.
Know I just need to find longer/smoother springs...but impossible to find the spring rate on mine.
I went with a Rough Country 3" lift leveling kit. 20" KMC DemoDog Wheels with -18 Offset, and with 33" Offroad Tires.
Edited by ZX14R BUSA KILLER
I’m looking to lower the back of my 2016 to level the truck out. Any suggestions?
I've read that you can just remove the blocks from the leaf springs and it'll drop the rear about 1 1/2". Google it, lots of info on it. Doesn't make it perfectly level, but makes it look much better from what I've seen.
Why does it matter with the RC 2' spacers if you install the bolts from the top down or if you have the nuts on the top of the strut since neither the head or not come into contact with the spacer itself?
The one thing I see with doing the bolts from the top down is that changing out the struts when its needed wont be too easy. From bottom up, it is a much simpler job. However. The bolts used are too long and would cause interference. Some have solved this by cutting down the bolts. But with that being said, I did follow the Rough Country installation directions and installed them from the top down. Hopefully it wont be for awhile but dreading the time when the struts need to be changed out...
Edited by mikeyk101
I was thinking the same thing. Is the interference with the cv axle then I take it? If so I might just measure the thickness of the stock configuration from bolt head to end of stock bolt and then just add the thickness of the spacer and cut the bolts right away. Just seemed like alot more work then needed when they could be put in the other way.
Yes, it is the CV joints that get in the way. If I had a way to properly cut the bolts down, I would have gone that way myself. I guess I could have just run out to the Menards or Home Depot and got the right sized bolts but at the time, part of the front end was in pieces so I had no way to get there, LOL!
I ended up just taking it all apart and doing it the right way. Start to finish it took me about 45 minutes to do both sides by myself this morning. Was way easier then I thought it was going to be.
I installed the Rough Country spacers on my 2017 Silverado 1500 this weekend.  I could not get the upper ball joint to separate.  I didn't want to use a fork and damage the ball joint or the boot.  The tie rod ends popped right out though.  Since the ball joints would not separate, I couldn't get one of the strut bolts to go in from the top because the axle shaft was in the way.  I put the bolt in from the bottom and noted that there was very little clearance between the end of the bolt and the axle shaft.  I ended up adding some washers to the head of the bolt to increase the clearance.  That gave me enough clearance and still had enough thread penetration for the lock nut to work.  I measured at the front fenders through the center line of the wheels, and they went from 36 1/4 to 38 inches from the ground.
If you ever need to get the ball joint separated, just hit the spindle with a hammer until it jiggles itself loose
Trust me, I hit it with a hammer!
Hey guys! I am new to the board but i bet i have read most of the 496 pages on this topic. I am interested in the 2.5 Rough Country lift kit and was wondering everyones thoughts? I have always had the 2 inch rough country kit on my previous trucks but was interested in this kit due to the rear block. I have 295/55/20 Nitto Ridge Grapplers on this truck now. I received a quote from the dealership i purchased the truck from and the kit plus the labor was quoted at $1200. I thought that was extremely high given the kit is $450. I was wondering what everyones thoughts were on the kit and also the price i was given. Any help is appreciated!
Finally bit the bullet and got wheelsand tires. My 2016 Silverado 1500 Rally 2LT with ready lift 2.25 and UCA and Zone add leafs.
I went with 2019 GMC Sierra SLT replica wheels in gloss black and LT275 65 R20 Duratracs. Upgrading from 285 45 22 bridgestone duellers. What a difference. You would never know these are a 10 ply tire. Great ride.
To prevent UCA rub, I fabricated some steering stops and tack welded them to the lower control arm. I made them over size and then ground them down to a perfect fit. Lost 6 degrees of turning radius as indicated on the dash, but i dont care about that. I rarely max out my steering. I did this so I didnt have to run a wheel spacer. Trimmed the corner of my mud flaps too. No rubbing at all982e4efd068e0214a1c489ee4a0979b9.jpg
Sent from my SM-G950U using Tapatalk
More pics. Pardon the excessive fluid film on the control arms lol. 06140ba1dafd8ae5df655596db4aba49.jpg15722f2b551ea1211f1026e9af359081.jpg6e751727a3466e897d112b640b02e82a.jpg420872c781b78649132dd738a3000e83.jpg
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 461 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
