Eibach pro level kit (kit includes front springs and shocks and rear shocks) set at 2.5” it is very close to level. I think it’s about 1/2 higher in the back.
Can i get bilsteins that will raise the rear of my truck a inch? I already have a two inch level kit in the front and it has pretty much leveled it out exactly. I would like to add only a inch in the rear to keep a nose dive. i have a 2018 chevrolet silverado
Get a 2 inch block to replace the stock 1" block and a set of Bilstein 5100 part number 33-238319 for trucks with a rear lift of 0-2".
https://www.shockwarehouse.com/index.cfm?mode=results&selected_model=3820&selected_year=2018
22 hours ago, langston1726 said:
Nope. They have a range of 0-1” lift I believe
0-2" 33-238319
how do you like the ride?  there arent enough reviews on this forum for the Eibach pro truck set up...
the ride is good, much better than the stock ranchos. No bouncing, little more stable in the corners. washboard isn't as bad.
When I had my 15 All Terrain, I had a dealer installed 2.25 Readylift with 3” rear blocks. I was running 275/65-20 KO2’s with no rubbing at all. On my new 19 limited now, I will be installing the Readylift 2.25 kit w/upper control arms and 3” rear blocks. Again I will be running the same tire. Apparently the new stamped steel uca’s are junk.
When everyone is talking about 2" leveling kits, are the blocks actually 2", or are they 1" (which raises the front about 2")?
I'm looking to raise the front as high as possible without too much ball joint strain (I was thinking 2" higher), and raise the back an inch higher
The front lower spacer is not proportionate to the lift height. On the rear it is but not the front.
There's a million pages of info on this topic but the bottom line is any lift in the front is going to put more strain on your ball joints than no lift.
Most people can agree that 2 inches is a "safe" height without replacing UCA's to correct the ball joint angle but you will find that some people raise it 3" and "don't have any problems" for years...
Jon
i called motofab to confirm this before ordering. they advertise based off the amount of lift, not the block size.
i went 2" in front, drove it for about a month and decided i wanted 1" in the rear as well. It is super close fender measurements but still looks like it has some squat. the 1" rear should be perfect.
The Readylift kit, 66-3086, the upper strut spacer is 1.5” and the bottom spacer is .75”. This they say will give you 2.25”. My 19 limited had stamped steel uca’s and Readylift says they are prone to premature failure. Something to do with the balljoint.
My question is do you think it’s nesessary to replace the control arms? Will they fail?
Perfect, thanks. I think I'll do the 2" front and 1" back
So the 2.25" was too much lift for the ball joints?
My truck was lifted to the max I think it had a 3” or 3.5” level kit “I bought it like that with 20x10 on 33s”, but I never had a problem with ball joints or anything...  I just upgraded to a full suspension lift maybe I got lucky...
20x10 on 33s with leveling kit
9” Suspension lift with the add a leaf
24x14 on 37s
(did frontend swap, it’s the same truck)
Edited by Frankielozano214
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
