Installing the can void any warranty?
Nope. I will be installing a prototype catch can soon built specifically for our engine compartments. Will do a detailed write up and review.
Ordered an RX can and should get it at the end of next week. I was looking at trying to do a group buy on them, but couldn't save people much money on them.
Drained tonight
Ryan
Is that the Mike Norris can? Mounted by the Alternator?
Drained my RX catch can last night after changing the oil. I don't remember exactly when I drained it last. I'm guessing about 2,000 miles on this interval. A lot of water in this drain (I'm guessing due to cooler outside temps). During the winter I think I'll try to drain it at least once a month.
So they still haven't addressed how to handle the passenger side line? This is only a partial fix.
The clean side separator only comes in to play under WOP or close to it.( Based on what RX told me.) CC is most of the fix. The clean side can wait tell budget allows.
When talking to RX about a catch can, we got on the subject of DI motors and the intake valve/guides coating issues. Big issue on Vett boards. Some have torn down engines at 6000 miles.
RX strongly recommended a CC for the new DIs to try and keep the junk off the intake valves. Just saying.
Edited by STex
Placed my order for the RX can just now, I have ran them on my previous vehicles and been happy with the results. Like say the new DI motors are a dry flow intake system so there is no way to clean the backside of the valves unless you run something thru the intake throttle body direction.
I guess the video is so much different than on the 5.3L motors. The connections on the throttle body are in the same spot, however in the video on the 6.2L there is simply one small line that needs to be disconnected. On the 5.3L there is a line going from the top connection at the throttle body to all the way back behind the motor where I can't see. The below throttle body connection goes about half way back on drivers side to the valve cover.
Wondering where these lines are capped, t'd, or removed all together?
Or better yet, can someone simply confirm that the connection above the throttle body remains, and that the connection below the throttle body to half way back on the motor is removed. The catch can is then ran in place of that lower hose, with each hose coming off the catch can replacing where they connect on the factory line?
So no t necessary and no capping off of anything, correct? I am thrown off as the kit included multiple t's and caps to cap off, but I assume that would be if I bought the other parts other than just the catch can?
Yup, that's the line to remove, below TB going to the driver side of above the valve covers.
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
    • Oil and filter threads are always a good time.  Especially when the BITOG discussion forums are cited as a definitive, technical source.    Countless single-data-point examples of why something is the best ever, or will destroy your engine... "they changed the shade of blue on the filter can, use at your own risk!"... "I've heard they changed the design to only have 64 pleats, total junk!"... "They're hidin' the NOACK data from us!  I wouldn't use that stuff in a cement kiln!".... "There was a guy who cut open Filter X (with a sawzall) and the anti-drainback valve was orange!  It used to be black!  Chinese junk!"   Good stuff.
    • I finally bit the bullet and installed a set of Bilstein 5100's on my 2024 Silverado 2500HD. My truck had about 75,000 miles and I've always felt the factory shocks were less than forgiving. So Bilstein 5100's are the most common go-to replacements. I personally have installed them on many trucks....2002 Silverado 1500, 2014 Silverado 1500, 2017 Chevy Colorado, 2019 GMC Canyon, 2022 Silverado 1500...now my 2024 Silverado 2500. I will eventually put them on my 2021 GMC Yukon as well. Great all around shocks.    Below is my video tutorial installing them on my 2500. As a bonus, for recently hitting 20,000 subscribers on my YouTube channel, I teamed up with Nick Scovel Jr at Scovel Motorsports to create a giveaway. Details are in the video description. Like, Subscribe and Share
    • Raven    About 2 more weeks and this Mirage will be two years old and already packing 54K miles. The CVT has settled in and is outperforming my expectations. The engine in quite, smoot for a three pot and very economical to fuel. Life time result to date is a stunning 52.44 mpg with a median tank of 52.74 mpg. Given the number of miles I drive and the cost of fuel lately this buy has turned out to be quite the winner in this stable.       She is also quite the teacher. Nice thing about a car that gets this type of milage is that you see the results of minor changes with the change instead of having to average a months worth of gas tickets to filter out the tank to tank scatter. Those lesson apply to everything in the fleet and everything I've done to the pack works with this one as well.   EPA numbers for this car:     This example is running 42% over the government values!!!!  😱    I am really enjoying this car. Can't even hear the laughing of those that thought this a 'dumb/disappointing buy".
