Saw it too. Some said it's a '16 clip front on a '15 truck.
I've yet to see a '16 Crew Cab at any of the dealers online, so that's probably right.
Any pain in the b.tt to install those tow mirrors, any extra drilling, connections?
You have to drill the 4th hole so the mirror can mount to the truck. As for the wiring it was all my own custom work but if you have a newer truck you can purchase the wiring kit to get them to work without running your own wiring.
No they are actually hitting the lots now. I looked online and seen a few. Mostly work trucks though
Yeah, saw a few the other day as well. Double checked the VIN beginning with 3.
Thanks! It's a bone stock no frills truck that will slowly evolve into something a bit nicer...
The guy who runs the shop I go to (Plaza Muffler in Orange, CA) allows the customer to try out different mufflers in order to get the sound they are looking for – so I will try at least two. I myself have always been a FlowMaster guy but those are more suited for muscle cars IMO. After watching YouTube videos on the systems put out by Borla, FM, Gibson (There are some good vids by Kinney’s Mufflers in Texas for Silverados), I’ll probably go with a Magnaflow single in, dual out as I really don’t want drone or have it be too loud. I will post pics when I’m done.
https://www.youtube.com/watch?v=9PoUlKYVpgg
That opens up a whole new discussion – cold air intakes.
Definitely like Magnaflow myself. I've got duals on a Grand Prix I own.
True duals would be an awesome set up though. :thumbs:
Edited by ChevyZ71Guy
What is the offset on your wheels? Are you running spacers? And are you only running the 2.5 level? Sharp looking truck! Nicely done.
-44 offset, no spacers, and yes only a 2.5" level. Thank you sir, love the stance, hate the trimming and reduced turning radius lol.
Picked mine up two weeks ago, and absolutely love it. Just got my Rough Country 2" in the mail, bed rug is on order, and tint and Access cover to come.
2014 Silverado Z71
9" Mcgaughys Suspension Lift
22x12 American Force Blades
35x12.50x22 Toyo MT
Edited by Neutril
2014 Silverado Z71
35x12.50x22 Toyo MT
Curious... does your lift/tire combo allow you to make it over that obstacle or would you still get high centered? Looking good!
my new addition, tradded in my 2007 NBS with 6l for this. i LOVE this truck.
it has running boards, the bow tie fiberglass mud flaps, gm hard tanneu and spray in box liner.
my first mod since i got it
Whats that 326 stands for?
I didn't really try because there was a tree in front of me out of the picture. But I'd imagine I would get high centered. When I go back home I'll try it out because now I'm curious.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
