Our biggest live post yet! - SEMA 2013
Zane
Those who dont follow the forum during the day time but check out twitter, keep an eye on @autoinsane @gmtruckforum and @GMTrucks_Chris
Sent from my Samsung Galaxy S4 using Tapatalk Pro
Ryan might as well start. You are on as much as me, yiu have no life
Conform
Pretty sure that will be updated during as well
Updating on Facebook would be better
We will update on facebook a little but the main place for stuff will be here on the forum.
Soooo many pictures to be taken
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
