Kind of a crazy question but has anyone purchased the corsa catback and had it welded together instead of using the clamps?
I want to get the corsa but a little nervous of someone just unbolting and stealing it. Hell even just unbolting and stealing the tip would piss me off.
I'm actually planning on getting the Corsa some time next year and was also thinking about getting it welded. Dont want to spend a grand and someone unbolt it and get it for free lol
Yeah that is exactly my thoughts. Hell just the tip is $200.
Ended up doing my side exit. Kept the same muffler just different pipes and tips. Love the looks. It’s def louder than before but still no drone in the cabin!
What muffler are you running?
Gibson MWA. 3" 2.5" dual out.
looking to add a bit more sound to the truck, Its a 2016 with the 5.3 and I've got a carven cat back competitor single exit exhaust  its been on for 2 years and love it just looking to add more. I've also got a diablew tune would adding some headers be what im looking for or go muffler less?
  Headers are going to completely change the sound the exhaust. A lot more rasp and airflow. That Carven will probably be too loud especially if you opt for no cats.  You could do a third cat delete. That will let a little more sound thru and shouldnt have any effect on emissions or drivability.
I’m running Texas Speed 1 7/8” long tubes with cats, single 3” back to a Dynomax 17267 muffler, followed by a Borla Atak crate muffler(400844). I absolutely love it. This is an iteration of several different set ups. In my opinion, it’s the perfect amount of volume, tone, rasp, and rumble. Quiet when you stay out of it but will wake the dead if you lay into it. You can hear it in the cab but it’s not drone, more you just feel the exhaust. Exhaust is so subjective though. Some people like it loud and deep, some like rasp and that glass pack sound, some like it barely louder then stock. It’s really up to you. This is my current set up. Rear window down just normal driving and medium acceleration.
 https://youtu.be/XYrJkJAuLlo
So i need options and opinions i currently run a Carven Progressive series catback on my 18 silverado 5.3l. I'm getting ready to have a kid and i would like to tone it back some but dont want to go completely back to stock. I love the current exhaust but it is a little bit loud inside and out. My thought are to just swap mufflers so i would need a 3" in and 3" out centered muffler. What do yall recommend? Looking for something not crazy just would like a little bit of tone to it. Thanks in advance.
If you are looking to tone it down then I would go with a 14” or 18” Magnaflow. It would still sound good but be much quieter.
It’s funny I have a 3yr old and a 4month old and I’m about to put a Carven R series muffler on my 2016. Lol.
Still the best sounding setup on the site![emoji817] let me know when you get tired of it lol.
Sent from my LG-G710 using Tapatalk
Can't really go wrong with a Magnaflow muffler. There are times I wish it was louder but it's nice at other times to enjoy the quiet in the cab.
My wife drives my truck occasionally and leaving the driveway she's got the gas a little heavy.
It's definitely authoritative and mean sounding outside. I have the 6.2 but the 5.3 would be similar.
Don’t know about all that but thank you. I appreciate it.
Np. To me its that pulse that makes the exhaust note better the the magnaflow. Sounds like a it has a truck/ Camaro exhaust if that makes sense. Quiet on light throttle and loud with a pulse on heavy throttle. Magnaflow is more of a flat drone with a dull pulse. Cheers!
speaking of pulse, Douge thorly makes a redesigned header that has two scavengers from the 4 primaries into a final collector scavenger, its designed to bump the low to mid power, on the 5.3, something these motors need more of.. I can only imaging guys bolting on the big 6.2 longtubes on a 5.3 and not making any bottom end torque ...
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,881 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
