I don’t get why the INEZ kit gets such a bad rap on here.
I have had both MCG on a 2014 and now a INEZ kit on my 2016 and honestly not much of a big difference in ride that I can tell and my alignment on both have been put back to factory spec.
I will say though it seems like when I go over a rough road or a pothole that the rear end does shutter a tiny bit harder then I would like. But kinda used to stiffer rides for having lowered cars all my life and a lowered truck I expected the same. Just jars me a little harder then I would love lol
Youll notice balljoints going bad way more often with inez.  I pull those inez kits off for local guys all the time
Is anybody running these belltech street shocks? Looking to upgrade over the ranchos that came on it.
https://www.belltech.com/products/belltech/lowering/shocks-struts/belltech-street-performance-9688.html
I currently have the 2 inch drop shackles in the rear and like how it sits. Might remove the rear block to get it more leveled out. Was looking for opinions on these shocks.
Anything is an improvement over the Rancho's - My brother ran those when he was at a 0/3 drop and it was a big improvement
Cool thanks for the feedback. My wife owes me an anniversary present next month so I think these will be it :)
I'm running them. truck rides great, big improvement over stock even at 4/6
Do you notice difference in the way the rear rides? Smoother would you say? I already have struts in the front and notice small difference.
Thanks for the feedback. Looking forward to getting these soon.
2016 with McGaughy’s adjustable drop set at 3/5. Just had the 24s put on today. Wheels are 24x10 +25 offset on 295/35/24 tires. Noticed some fender liner rubbing in reverse, may have to mess around with it to see if I can zip tie for a quick fix.
Next on the list is to remove the side steps... was lifted before haha.
Question for the bigger brains in this thread:
What I'm currently running: 2017 CCSB Silverado with stamped arms, Belltech 25004 lowering struts set to the lowest setting (the one slightly taller ring) in the front, and I have the rear brought down with a pair of McGaughys 33037 1"-2" drop shackles on the lowest setting with the block removed.
What I want: Before the Belltechs I was leveled and the plan was to bring the front end down a little to minimize the squatted look it would have depending on where it was sitting (an optical illusion from street inclines).  With the additional drop in the front, I now want to bring the back end down either to level or just a bit higher 'because aesthetics.'
Finally, the question: Assuming I'm  currently at a 2.5"-3" drop in the back, is my only option for bringing the back end down further to a 4" or 5" total drop going to be installing new hangers and replacing the stock shackles?
Flip kit and lift hanger for the rear
Finally got lowered. Referred to this thread a lot and thanks to the community for posting opinions and experience. Went with 3/5 belltech spindle & adjustable SP shocks up front, flip kit with lift hangers out back also with SP shocks. Couldn't be happier with the ride. Not overly firm but much more stable in turns. No shakes, vibes, or issues.
Does anyone have any strut spacer rings laying around that they dont need? I'm thinking about adding 1 to each side to try and get rid of the minimal running I have.
I have some Belltech rings you can have, just let me know where to send them.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
