I don’t get why the INEZ kit gets such a bad rap on here.
I have had both MCG on a 2014 and now a INEZ kit on my 2016 and honestly not much of a big difference in ride that I can tell and my alignment on both have been put back to factory spec.
I will say though it seems like when I go over a rough road or a pothole that the rear end does shutter a tiny bit harder then I would like. But kinda used to stiffer rides for having lowered cars all my life and a lowered truck I expected the same. Just jars me a little harder then I would love lol
Youll notice balljoints going bad way more often with inez.  I pull those inez kits off for local guys all the time
Is anybody running these belltech street shocks? Looking to upgrade over the ranchos that came on it.
https://www.belltech.com/products/belltech/lowering/shocks-struts/belltech-street-performance-9688.html
I currently have the 2 inch drop shackles in the rear and like how it sits. Might remove the rear block to get it more leveled out. Was looking for opinions on these shocks.
Anything is an improvement over the Rancho's - My brother ran those when he was at a 0/3 drop and it was a big improvement
Cool thanks for the feedback. My wife owes me an anniversary present next month so I think these will be it :)
I'm running them. truck rides great, big improvement over stock even at 4/6
Do you notice difference in the way the rear rides? Smoother would you say? I already have struts in the front and notice small difference.
Thanks for the feedback. Looking forward to getting these soon.
2016 with McGaughy’s adjustable drop set at 3/5. Just had the 24s put on today. Wheels are 24x10 +25 offset on 295/35/24 tires. Noticed some fender liner rubbing in reverse, may have to mess around with it to see if I can zip tie for a quick fix.
Next on the list is to remove the side steps... was lifted before haha.
Question for the bigger brains in this thread:
What I'm currently running: 2017 CCSB Silverado with stamped arms, Belltech 25004 lowering struts set to the lowest setting (the one slightly taller ring) in the front, and I have the rear brought down with a pair of McGaughys 33037 1"-2" drop shackles on the lowest setting with the block removed.
What I want: Before the Belltechs I was leveled and the plan was to bring the front end down a little to minimize the squatted look it would have depending on where it was sitting (an optical illusion from street inclines).  With the additional drop in the front, I now want to bring the back end down either to level or just a bit higher 'because aesthetics.'
Finally, the question: Assuming I'm  currently at a 2.5"-3" drop in the back, is my only option for bringing the back end down further to a 4" or 5" total drop going to be installing new hangers and replacing the stock shackles?
Flip kit and lift hanger for the rear
Finally got lowered. Referred to this thread a lot and thanks to the community for posting opinions and experience. Went with 3/5 belltech spindle & adjustable SP shocks up front, flip kit with lift hangers out back also with SP shocks. Couldn't be happier with the ride. Not overly firm but much more stable in turns. No shakes, vibes, or issues.
Does anyone have any strut spacer rings laying around that they dont need? I'm thinking about adding 1 to each side to try and get rid of the minimal running I have.
I have some Belltech rings you can have, just let me know where to send them.
    • I really appreciate the response.  I guess I was confused about torque angle vs torque angle yield.  The individual bolts don't have a warning on reuse but the part number for the LCA nuts does.   Regarding the purpose of the moog grease fittings on their bolts .. Guessing to reduce possibility of corrosion locking the cams or seizing to the bushing inserts.
    • The top speed is software limited, I don't think there's a way to change it without de-doing the whole truck. If you can get a CAN log per my above post we can try seeing if there's anything obvious going on. What happens when you plug the truck in to charge it, does it ever fully charge up or does it stay at low battery %?
    • The LCA bolts are NOT a one time use fastener.  GM does not have them called out as such at all.   They are torque plus degree, but not a one time use TTY.  Nowhere in the service manual does it call out for replacing the LCA bolts for being one time use.  The factory spec would apply to the Moog bolts as well.    I see two things different.  The Moog bolts are greaseable (which I see no point in) and they don't have one of the washers welded to the bolt like the factory bolts, so they can be used in all 4 positions.      Think about it.  The LCA bolts are now the alignment adjustment point, instead of the UCA bolts like the prior generation.  A bolt that is meant to be adjusted for alignment...would it make sense to make it a one time use component?  How would you get an alignment done in the first place?  You couldn't.       Also.  What TSB exactly?  There is no TSB that I see for 2019-2026 for over-torquing LCA bolts.  There was a PI, PIT5533C, but that covered 2014-2018 body trucks for re-torquing LCA mounting bolts.  But those trucks to a 2019-2026?  Not the same, so PIT5533C does not apply.
    • Nice looking setup!  Is this the kit you got?  If so 211 is a great deal!  https://accessories.chevrolet.com/product/trailering-camera-system-86584184   My TT came with a wireless rear camera but it only works on an app or a separate screen they sell so I've decide it's not worth the hassle since it keeps disconnecting and with wireless android auto it's a hassle trying to connect my phone to it.  So I've been thinking about adding the GM camera so it's integrated into the rest of the camera views.   I also found this one which seems to be a different PN & retail price that explicitly states the invisible trailer view https://www.shopchevyparts.com/chevrolet/2024/silverado-2500-hd/electronics/85825715-silverado-2500-trailer-camera-transparent-view-requires-trg-camera-provisions-p-92326971.html?sort=2a
