This could have something to do with a poorly made door flap or the door actuator not performing a full sweep when commanded. Perhaps some air leakage past the recirculating door?
Edited by pm26
Enthusiast, What do you mean by monitoring? I have brought up the idea to them to use a smoke test and they stared at me like a dear in the headlights.
Who is "ethusiast"? (the real screen name is in blue letters in the left upper corner).
Edited by pm26
Sduff, What do you mean by monitoring?
take2. I would like to answer your question but I not sure what you are asking. I went back and look at all of my posts but I don't see anything that I have said about 'monitoring' other than mentioning the GM Customer Service 'Monitor' in this Forum. Can you help me out here....
Steve
Hopefullly we will be getting to the bottom of this issue. With the help of our GM Customer Service Monitor my truck is scheduled next wednesday (12 Feb14) at 0900. Evidently GM will be involved in diagnosing the problem. I already told the service technician that called to set up the appointment that they will need to do some real world testing and not just let it set in the service bay. He mentioned something about a 'smoke' test....this should be interesting. I will let you know what the results are after I get back on Weds.... Get the popcorn ready!!!
Well the results are in and I couldn't believe what I was being told....I have attached the write-up so you can read it for your self....You may not want to have a truck like this if you live in areas that have tunnels. I was in Virginia for a while and they would have accidents that would close down the tunnels. I guess you would die of carbon monixide posioning sinse you can't keep the outside air out...Happy reading. I can't begin express how disappointed I am in the poor design of this expensive product.
Unreal.
Does GM still have that money back guarantee? I want to get rid of this thing.
Edited by VMaxtastic
My question is. can you acces the flap that is the problem through the glove box. If so you should be able to do a little mod to make sure it closes all the way. Or maby seal it shut.
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Are you guys who see this living in cold places where it may not close fully to prevent fogging?
I just got off the phone with customer service. So I have all my issues documented at least. Skunkstripe, I'm going to be asking the service manager when I finally get it in, where exactly the air comes from, so I can plug it off some how.
Edit: @ Mike.... Yes I'm in a cold place. Isn't Michigan cold? Are you not noticing this problem? The windows on this truck fog up more than any truck I've owned anyway.
This iceberg is absolutely cold. :lol: I have a 2011 and honestly I can't say I frequently use recirc but if I get behind a smoky truck I do switch it and it seems to work ok.
The air is coming in from the outside at the bottom of the windshield below the wipers. There are vents there and when the smoke was introduced into that area it began to fill up the cabin with the smoke. Now I wasn't there to see it, this is what the Service Tech told me. And I don't believe they traced it to see exactly how it was getting into the cabin. They then called GM and was told this is 'Normal'....I guess we sure wasted a lot of time here with this since it is 'NORMAL'. I love my truck but this will take some getting use to since there doesn't seem to be any interest in fixing the 'Normal' problem. They must think we are all stupid or something, going to sleep.....i've been driving for over 40 years and that's never made me feel like going to sleep...if you wanted some fresh air you cracked the window a little bit. What a joke!
Edited by sduff
Gm called and said they may have a fix for us...They said when the vents close they still stay open about 10% (WOW). Anyway they said they can reprogram the onboard computer and change the level of closure. I will be doing it this weekend! I hope it works.
Yes I think its due to the windshield being slanted more on the 14's and the defrost is too far back. I can't even keep the wiper thawed.
Keep us posted! Thanks for mentioning this!
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
