I recently removed my factory Chevy Silverado Crew Cab  4" assist steps and would like to get rid of them. Does anyone have any recommendations on how i could sell them? I have tried craigslist and have not had any luck. Would anyone be interested buying them? I live in CT.
Sorry for the off topic comment.
5a8c345579d0f_ScreenShot2018-02-20at9_43_34AM.png.769efdf8d1c0a75e8630f9ab2aa128e5.png
I’ve had pretty good luck with Facebook marketplace or some of the apps like OfferUp and letgo. More places you post, the better. Can be tough though with how cheap some of the aftermarket steps are these days. Also, there’s a for sale section on the forums, but I believe the post minimum is 50 to post in there.
On 1/29/2018 at 12:45 PM, cgalpha08 said:
Has anyone installed a set of the Go Rhino RB20s? was looking at these as a more minimalist approach and tossing the drop step onto the passenger side for the GF. Thanks.
I've also been scoping those out. I really really wish they had a wheel to wheel version available. Would make accessing the bed so much easier.
What would be a good price to sell my assist steps for? $100?
Thank you for the help guys!
Anyone with RB10s, RB20s, or D6 dominator steps? I'm on the fence.
To be honest I would probably have ordered them if I didn't have issue with their finish in the past.
Sent you a message
don't like them IMHO power running boards should not be seen that is why i like my AMP research boards, and the AMP's have some flex as well
My Amps have ZERO flex.  :P
6 hours ago, TruckDaddy said:
I believe it's the Jeep that's flexing, not the steps.  We will see what happens on a truck.
No sir, it's clearly the mounting brackets for those steps doing the flexing.
37 minutes ago, TruckDaddy said:
The way the brackets are engineered, I don't see how downward force is going to flex the brackets.
I don't know either, but I'm watching the same video you are, and the man (who looks to be 200lbs - way less than the 650lbs max they indicate) is causing them to flex substantially.  Probably the mounts or the mounting points (body sheetmetal?) or both.  Either way, it's moot to me because they're as ugly as homemade sin!
Edited by lapoolboy
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
