On ‎9‎/‎8‎/‎2018 at 1:46 PM, Osirus said:
This means I should be able to run:
HMI -> Front Console Hub (Green to Grey cable)
HMI -> Inner Console Hub (Black to Brown cable)
Front Console Hub -> Glove Compartment Port (generic Mini USB extension cable) https://www.amazon.com/gp/product/B015HKPDAE?pf_rd_p=d1f45e03-8b73-4c9a-9beb-4819111bef9a&pf_rd_r=HJVW9D9NJGNQETAPW9T4
Update:
I finally got a case of the not-lazys long enough to try this. I rearranged my setup as described above and am happy to say that (for the moment) everything is now working. All USB ports play media as well as AUX.
At first AUX didn't work. This port seems really touchy. It kept saying no other devices connected. I was testing it with a little Sandisk MP3 player. I finally swapped it out for my phone and then it started playing. I later swapped the Sandisk player back and it worked, too. I don't know what the sensitivity is for detecting the input. I doubt I'll ever really want to use it, anyway.
[mention=159655]pgamboa[/mention], any updates on when that shop you're working with will be resuming business? I'll be looking to do the center console swap in the next month or two.
Still working on it. I am working with another supplier and trying to get the best price possible to pass on the savings. Also, note that there are a TON of options for things like trim. So we are working on the most common type of console requests.
Hoping by next week... I should have something.
Sounds great, I will get with you soon to order your harness once you hear something.
On 6/15/2018 at 12:35 PM, Hubbstx said:
mitchell95: I just finished my swap. Ordered all partsfrom Corbin with gmpartsnow.com. I spent hours researching prices and they were by far the cheapest to the door. I have a 2018 Silverado Crew with black interior w/silver stiching.
84288040-Console $390.79
84092079-Upper Trim Panel $146.57
22467516-Side Trim $52.96
23467516-Side Trim $25.30
22776807-Front Bracket $16.58
84022323-Cable $16.46
19119050-Cable $24.13
11609982-Bolt x 2 $3.26ea
Total $680.31
10% Discount -$67.93
Shipping to my location $54.53
Grand Total $665.91
You will also need the wire harness from pgamboa he will hook you up...
Hope this helps
Sent from my SM-G935V using Tapatalk
how’d you get the 10% discount?
Looking at 2018 LT Z71 trucks now.   One question that maybe someone can answer.  Has anyone looked at adding a 2 port USB like on the front of the console to the rear opposite of the 12v plug?  See the picture... Would not have to have the full connectivity, just charging...  I will be putting a console in a new truck if I do not get one with it...
Looking at doing that to mine.  Actually, looking at (already have the parts for) replacing the DC outlet with a tandem USB outlet and a slave set on the other side, power only on both sides.
I have a question the consoles I hope someone can help with.  Trying to avoid ordering a replacement console that doesn't work/match.  I have the top and side trim pieces so no worry there.
The situation:  My 2017 Sierra 1500 SLT came with a factory center console.  The console was destroyed when someone decided they wanted the console vault that was in it.
Dealership told me I need GM part # 84199890 replacement console to replace with the black interior with white/silver stitching.   I would love to get the wireless charging to work as part of this ordeal.  Reading through the threads, looks like GM part # 84288040 is from the 2018, and the wireless charging works.  Anyone know if this console is compatible with a 2017 truck?
I attached a picture of the connector from my original console if that helps.
Also, pgamboa, happy to donate my original harness to you after I get a new console if it helps your services.
Thanks in advance for any help,
-SSam
-SSam
These are confirmed to have the 2018 charging lid and white stitching.
84288042 - Console (Black with black lid handle)
84288045 - Console (Black with chrome handle)
Ha! That’s funny using my pic to ask that. Seems like a good idea though for passengers to use
Hey Phil,
The 84288042 is backordered all over with no ETA. Is the only difference between the 8042 and 8045 the chrome handle? Do you know if the 8045 will fit a Silverado?
Thanks,
Jim
Hey Phil,
Thanks,
Jim
Yes.
26 minutes ago, pgamboa said:
Yes.
FYI...8045 is backordered everywhere as well. I'll just have to wait it out.
Jim
    250.3k
    BryantM4
    BryantM4
  • Who's Online   6 Members, 1 Anonymous, 758 Guests (See full list)
