Was working on wiring up the rear lights and discovered an axle seal leak. I guess it is time for some you tube.4811432eea6b8ab46ea59ca4dc88e577.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
All installed! Took me longer due to actually taking my time to make sure everything was correct, and because it was hot lol. Found out why my passenger side HID wasn't firing, and it wasn't the striker from what I originally thought. Turns out one of the relays in the dual relay harness went bad. Guess that's a good design, that way you don't lose both headlights at once. Luckily I had one that fit the bill until I can order the correct one. Here's some pics
Running lights on
Running lights + fog lights
Running lights, fogs, HID lows
Lows and LED highs
Overall the cosmetics and lines of the truck flow better. Hopefully they throw a decent amount of light out. Headlights are Winjet for 14-15 Silverado, the fog lamps are Morimoto Type C LED fog lamp direct fit replacements. May need to adjust everything a little more since it wasn't even dark out yet, shouldn't be too bad though
Sent from my SM-N920V using Tapatalk
Don't forget the bcm diode trick to get your fogs to stay on with your high beams
Running lights on
Lows and LED highs
Came out great so do the drl turn on all the time automatically or do you have to turn it on with a switch or something
Didn't do a whole lot with her, this morning, after work. Tried to tint the top of my windshield, but first pieces ended up not sticking, will reattempt in the next few days. After that, I detailed the inside, cleaned the windows (in/out) and dash-glass, cleaned the water marks off the chrome parts, removed my wife's makeup residue from the steering wheel controls (HOLY CRAP, I CAN SEE THE ICONS AGAIN!!!), and wiped the dust from the dash, center console, and doors.
Unfortunately the last time I checked, in VA you can only have a max of 4 forward facing lights on at a time
The drl strips come on when the running lights come on. So when the regular low beam drls fire up the strips aren't on until the running lights are on. Hopefully I didn't confuse you too bad
Washed him today, looks tons better, especially with all the mud gone. Checked the alignment of the air dam, did some off roading last night and skimmed a dirt mound rumbling down a dirt trail. scuffed it just a tad, but no worse for the wear. Onward!
Put on color matched bowties, cleaned up and dressed some trim in preparation for a tonneau cover that the FedEx man is supposed to bring me in about a week. I'm not sure about the vinyl bowties yet as they are not a perfect match, but considering the very low cost and ease of installation I will look at them for a few weeks and decide. Dressing the trim seemed like a good idea before the cover gets here. I used Trinova plastic and trim restorer and it is very easy to use and leaves my preferred satin finish. I don't like the ultra glossy shine, but I want a touch more than a flat finish. Lots of good Amazon reviews and Youtube love, but I will reserve judgement until I see if it lasts and or runs down on the paint after the first rain. It is a rub on wipe off product and I followed the directions, but added a few minutes of sitting on the plastic before I wiped off. I tried to really emphasize the wipe off step because I hate it when "that other product" that we have all used at some point runs down on the paint. One other little trick I would like to pass on is how to get wax off of the trim. If you have any Magic Erasers around the house, dip one in a little water and it will take wax off the trim with ease. No matter how careful I am, I always get a little wax on the trim and it is nice to have a cure.
20170818 142605 001
20170818 142540 001
20170818 115615
20170818 115604
Got some lighting done, more to go. Tapped LED dome controller for interior and picked up the bed light harness for the bed.
I gotta get these bed lights, they look clean and would be great under the tonneau at night too
Unfortunately the last time I checked, in VA you can only have a max of 4 forward facing lights on at a timeThe drl strips come on when the running lights come on. So when the regular low beam drls fire up the strips aren't on until the running lights are on. Hopefully I didn't confuse you too bad
So your only using it with high beams? Shouldn't be an issue as you switch them to low beam as soon as you see oncoming traffic.
No the fogs are on with low beams only and then kick off when I turn on the high beams
Covered under powertrain right?
I wish, the truck has been regeared to 4.10s which pretty much ruined that warranty.
On a brighter note G2 axle finally has their diff covers available. I ordered one from 4 wheel parts.
Should have everything by Wednesday to do the job next weekend.5504dee7b4c98e12d4e7086610790b99.jpg
What kit did you use and where did you tap it to connect to the dome light. I would like to do the same as well.
Sent from my Pixel XL using Tapatalk
There's a gray wire in the gray wire block under the driver's side dash you tap into. There's a few pictures in this thread that point it out. As for the lights I ordered individual LEDs and made my own harness. You just ground to one of the bolts in the same area. There's one just under the carpet and another under the trim.
Got her tinted today. 70% Ceramic on back doors and back glass, 20% ceramic on front two doors, 5% ceramic brow and 70% ceramic on windshield. Love the way it turned out!8db71b0c3b561421491338dc415e6a60.jpg
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
