On 6/29/2020 at 8:22 AM, Codman67 said:
That’s the size I’m lookin for looks good how’s the ride never had BFGoodrich before I have the 285/55/20 Hankooks that came with mine.
Ride is pretty good for an all-terrain type tire.  Rear end skips around occasionally when going though thru sharp mid-corner bumps.  Not sure if that's the tires or the suspension though.
13 hours ago, NITTY said:
Close up
Looks really good, how noisy are they at freeway speeds?
I’ve never had aggressive tires before so that’s hard for me to answer.  They definitely have a howl to them but it’s just my weekend ride so it doesn’t bother me.
Got it, thanks for the reply. It will help me with my decision on new tires.
On 7/20/2020 at 11:48 AM, bugzz2010 said:
2016 Silverado 1500 4x4  2" Level, Air Bags in rear and Monroe Load Lifters
285/65/18 Nitto Terra Grapplers on 18" Tahoe Stocks
Good looking truck, where did you get the 4X4 badges from? They are pretty cool looking.
GM Replica wheels 22x9 with Nitto Ridge Grapplers 305-45-22.  ReadyLift 2.25" front level, replaced rear 1" block with 2.25".  No rubbing.
Edited by Luster
  • Like 4
2.5 motofab up front. Back lifted 3/4 in. Factory 22s with Factory size tires for now. Will have 33s next year hopefully.
Looks great man! Hey, where you been?
That color is popping!!! Love this truck but I miss the sanoma red on my '14!
I love the color I try to clean this truck whenever I can. Its amazing gleaming in the sun.
I only trimmed the fender liners! I took out quite a bit but now they fit no rubbing with normal driving on the street and in parking lots. Even in reverse full lock, no rub.
I don't do much off roading but they would rub most likely.
Sent from my Pixel 2 XL using Tapatalk
Been a little while since you posted this. How you like the set up? No major rubbing?
Sent from my SM-G892A using Tapatalk
Yea Im loving it man. Only time it rubs is when I back out of the driveway and its at like halfway turned. Its rubbing on the plastic cap on the cab corner. Its very minor and I dont intend on doing anymore trimming. If i turn it full lock it moves past and doesnt rub.
[mention=210948]IronVilkas[/mention] I'm running 275/65/20 right now and love the extra height, but the Nitto G2s are almost done after 70k miles and I want to go with something wider while keeping the height. The setup you did looks great and is probably the tallest tire you can fit with a level.
I need to change wheels anyway, these came with the truck, 20x8.5 +35, they keep the tire tucked pretty far with the offset.d124cdd4effedcde865209c6575c75b7.jpge0d7d0a709f769317529c38238689c29.jpg
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
