Why hasn't anybody painted what use to be valve covers.I haven't seen any covers painted on the 5.3. I know it's not a valve cover,just thought it would look better to match the cover that's not included with our trucks.
Coil covers painted. Engine bay plastics all painted by my local body shop, they matched my factory paint code. All of you with brighter color trucks would probably get more contrasting pop. It fits my style, so I am pleased.
How much did that cost ya?
Do they make a 5.3L emblem?
Yes. Look closely. Right under the BowTie.
I just traded in my 2014 Silverado for a new 2016 GMC with 5.3 engine. I took the engine cover (plastic silver cover like in the photo below) off my Silverado but there is nothing to hook it up to my GMC. Can you use this on a 2016 GMC? If so, what do I need to do so? I want to check before I get the new badge.
Edited by PMattras
Hey Guys sorry for my mistake. Must have been distracted or toooooo many suds. The Correct part number for the 2 front studs that hold this cover is 11611691. I put in 16616691. Whoops. Sam
Here are the stud PNs. I would assume that this is what you are missing on your truck. Can anyone confirm that these studs replace the existing bolts on the newer trucks? I have bolt heads in the stud locations on my 16
Yes, they replace the two bolts, actually screw type thread. I just put them on my 2016 silverado.
Very informative thread! This type of Thread makes listening to all the whiners on other Threads worth it! :thumbs:
Finished mine a while back, have yet to put it on. Actually had spray painted it the factory color and 2K clear coated it.
6.2 engine cover
Edited by hpd562
  • Like 5
Finished mine a while back, have yet to put it on. Actually had sprayed painted it the factory color and 2K clear coated it.
What's the part number of that gmc emblem?
Damn that looks good!
RT
Let me do some research for you, can't remember off top of head. Got it from the engine cover of a GMC Terrain. Fits perfect.
RT
Thank you sir
Can anyone show me (photo) what bolts have to
be removed to put the studs in? Are these bolts hard
to remove and can you cause any additional issues or
problems? I don't know too much about this. Specs -
pounds pressure putting the studs in etc..
I like to do it because I have the item and it is
pretty cool looking? Thanks.
