Bed Covers... Why charge more for newer trucks?
This may have already been posted, but I couldn't find it...
From 04-19 the bed size of the Chevy Silverados are very similar. Less than 1.3" in either direction for the 5'8" Crew Cab beds. We have purchased 14-18 covers that fit perfectly on 2019's. With a measurement, I could determine if I should purchase two of the 04-06 covers for our other 2019 trucks.
Here's the inside dimensions I have found online for the trucks:
04-06: 68.13" x 63.19"
07-13: 68" x 63.63"
14-18: 69.33" x 62.33"
All of the covers that I have purchased will overlap the side rails by about 2" and tailgate by a little more, which in theory would mean that they would fit various trucks just fine. The problem is that none of the sellers post the exact dimensions, nor will they give that information when asked.
I suppose this is so that buyers will have to buy the more expensive covers for the newer year trucks. The same covers, made from the exact same materials vary in price from $299 to nearly $900 from vendor to vendor and year to year. I understand supply and demand, but this simply feels like price gouging.
Anyone have any experience with this? I have put the 14-18 covers on 2019 trucks, and they fit just fine. Just wondering if the plethora of 04-06 $299 covers are of similar size.
Anyone know?
You try going to a salvage yard. I got my last cover from a yard for my work truck. They had no problem me measuring to make sure it fit. So you could try finding one for 04-06 and measure it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
