Added picture of the wheel/tire setup. I love how they look. They have a textured finish that is almost impossible to get dirty. Just rinse them off and they are good to go. I wanted something other than the normal fuel wheel setup most people have.
  • Like 4
Great write-up and pics. Thanks. I've been researching different options on leveling + wheels and tire sizes. It looks like you have the stamped UCA's. Any issues with rubbing or flex with wheels on? I was looking for a Midnight Edition with a 6.2L and they were tough to find. I ended up going with a High Country with 6.2L. All over the place on wheels since I have the Iridescent Pearl Tricoat. Black is easy. I'm was thinking of doing the Bilsteins and upgrading the UCA's. Ready Lift has the level kit with tubular UCA and I was contemplating doing that and adding the Bilsteins 5100.  Not sure if that's overkill. The spacers would give me a hair more lift. I'm thinking 275/60/20 or even dropping down to 17" rim and 285/70/17. Ride quality is important to me. Nice looking truck.
On 4/24/2019 at 1:19 PM, Battle Born Offroad said:
We do for $120 with new KYB mounts.
I just want to be clear that you're talking about a set of preassembled 6112s with new KYB mounts ready to be bolted in place? Meaning I don't need to disassemble the factory coilover at all beyond removing it as a unit? Thanks.
Sorry for being a repeat offender.... What is exactly needed to go from Crapos to 5100s?
On ‎4‎/‎26‎/‎2019 at 12:07 PM, Silverado-Hareek said:
Correct the orientation shouldn't matter from a performance standpoint.  But the reason they suggest boot down is to protect the main shock body from damage as it houses the guts of the shock.  Also, if any dirt or moisture were to get on the piston, it would flow away from the seal where the piston enters the main shock body rather than settle around the seal.  I'm not sure if it makes a major difference as Bilstein sells shocks that go in either direction, but technically the 5100's are intended to be installed boot down and for these reasons which is to protect the shock and make it last longer.  Do with that info what you will.
Not to argue as this is a personal opinion and to each their own, but....  look at most all factory shocks.
They are Body down, boot or cover up. Including the factory GM Rancho branded Tenneco shocks that come on Z71s. Body down with plastic cover over the shaft at top.
And how many truck owners actually take them off road anyway?
23 hours ago, z71skywalker said:
The ride has improved so much from the stock Ranchos.
AMEN !  The reason why I created a poll on this very subject.
I considered this when deciding what to do with mine.  After a lot of research, I found opinions going both ways.  I also found that there are many after market shocks with a boot down design/orientation.  Ultimately, I decided to go with Bilstein's recommendation on the orientation which was further supported by the mechanic that installed them for me.  Additionally, the boots on the 5100's have drainage holes in them so when oriented with the boot down, the drainage holes are at the very bottom allowing for any moisture to flow out of the boot.
Edited by Silverado-Hareek
I was going to say bilstien did recommend in writing boot down. Not sure why they stated a different over the phone. Maybe it's a new salesperson or something.
Sent from my LG-G710 using Tapatalk
I got my Rough Country 5" knuckle lift last week with the bilstein 5100's up front. Had them on 2nd notch from bottom and it sits perfectly.
Correct, that $120 includes assembling the shocks and any necessary hardware we need to do so
Just wanted to post that I received my Bilstein 6112's from Battle Born Offroad yesterday afternoon (drop shipped direct by UPS from Bilstein).  i didn't have any tracking info, so it was a nice surprise.  Ordered them around March 29th.  I'm hoping to do the install this weekend if I can find the time and I'll post my impressions.  They look crazy stout, can't wait to feel them in action!
  • Thanks 2
I plan to install the 6112's on my truck this week. My truck is/was equipped with the magnaride shocks, so I had to purchase aftermarket top mounts because the OE top mounts were too narrow for the shafts on new Bilsteins. I just received the KYB top hats and they don't seem to fit the Bilstein springs flush or snug. There's quite a bit of play between the upper spring seat and the spring. I'm concerned that when the spring becomes compressed around the new top mount, there's not enough of a brim on the top mount to keep the spring compressed or in place. Is this amount of play between the top mount and spring common? Or should I be concerned?
Edited by Randys Denali
On 4/25/2019 at 2:46 PM, Battle Born Offroad said:
2014-18 GM 1500 Bilstein Options & GM Trucks Forum Discount
Use code GMTRUCKS for forum discount
Bilstein 4600 Front Shock - 24-238281
Bilstein 4600 Rear Shock - 24-238298
Bilstein 5100 Front Shock - 24-238304
Bilstein 5100 Rear Shock 0-1" - 33-238319
Bilstein 5100 Rear Shock 3-4" - 24-186636
Bilstein 5100 Rear Shock 5-7" - 33-187228
Bilstein 5160 Rear 0-2" - 25-242515
Bilstein 5160 Rear 1-3" - 25-187601
Bilstein 5160 Rear 3-5" - 25-197761
Bilstein 6112 Front Pair - 47-273702
Tried to order from your site and emailed no response to requests.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
