Yea I think that makes sense. All the force goes through the shock/lower control arm instead of through the balljoint/upper control arm. Still not a good idea to hammer on the shocks that hard. It would probably wear out the seals and stuff early. Not that you ever do that much on the road.
I went with the Eibach leveling kit so I am at around 2.5in level so I definitely wanted to get some upgraded UCAs to help the angles. I don't think 1.8 inches is gonna hurt anything but I just don't like that the upper balljoint is held in by a piece of sheet metal on my truck. If I had the cast steel or aluminum I probably wouldn't have switched or waited until my baljoint was worn out to switch
On 2/16/2020 at 8:59 AM, Jdub289f said:
That’s good the hear! With my 5100s it felt more controlled but the stock coil doesn’t seem to be good at all. Almost like it’s maki  nag the shock do too much work. I’ll have to get the 6112 kit when my funds allow it. Should be an easy swap without having to align it since I already have the 5100 adjustables on there in the max height.
actually that's what you want if you have a good shock.....spring just supports the vehicle and shock is responsible for dampening, spring shouldn't get in the way of shock doing its job....if you have more dampening maybe can get away with lighter spring.....but yeah you want the shock doing most of the work....
Ok needing some help deciding. I have a 2014 Sierra crew cab 5.3L z71. Right now I have a 2" level in front that mounts under the strut (1" in thickness for 2" lift). Nothing in the rear. I have 275/70/18 on stock rims. No rub noticed on pavement or off road.
I have 1-1.25" of rake and I like the way the truck sits. But I want to change the shocks to either the bilstein 5100 or eibach pro truck sport. I'm keeping the stock springs and losing the spacer.
I know what the literature states for what sort of height increase to expect. But I'd like some real world #s. I've read this thread and some seem to be getting more lift than the reported #s. Please let me know your rake with this setup. Thanks!!
the eibach kit with eibach spring sits higher than same kit with stock spring....i believe its about 1" difference more lift....so when your reading stuff note whether its stock spring or eibach….both work on same kit.
Edited by Dunn
Yeah for sure, I'm talking about with stock springs. Just changing the shocks.
1 hour ago, BBinnj said:
not seeing that anymore- showing at $702.99 now...
Just checked. It is.
Well after as much reading as i could do on this Thread I've got everything set up to go on this month on the 26th.
Items are:
-6112 kit for front
-5160's rear
-Kryptonite UCA's (KRUCA13)
-Fuel Blitz 18x9 +1 offset
-275/70r18 Kenda RT
-1" Shackle for rear
-Zone trim plates
2018 Silverado w/ 13k miles
Items are:
-6112 kit for front
-5160's rear
-275/70r18 Kenda RT
-Zone trim plates
You likely won’t need the trim plates. I would hold off on installing them until you get the tires put on
I was planning on that originally but these tires run large for a 275/70r18 at 33.45x11.23. Plus i do plan on taking it offroad so just would rather remove any risk of rubbing at the same time as getting the rest done.
Quick picture after picking it up, will take more tomorrow: 6112’s and 5160’s
Looking forward to more pics? How did the trim plate install go?
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
