Yea I think that makes sense. All the force goes through the shock/lower control arm instead of through the balljoint/upper control arm. Still not a good idea to hammer on the shocks that hard. It would probably wear out the seals and stuff early. Not that you ever do that much on the road.
I went with the Eibach leveling kit so I am at around 2.5in level so I definitely wanted to get some upgraded UCAs to help the angles. I don't think 1.8 inches is gonna hurt anything but I just don't like that the upper balljoint is held in by a piece of sheet metal on my truck. If I had the cast steel or aluminum I probably wouldn't have switched or waited until my baljoint was worn out to switch
On 2/16/2020 at 8:59 AM, Jdub289f said:
That’s good the hear! With my 5100s it felt more controlled but the stock coil doesn’t seem to be good at all. Almost like it’s maki  nag the shock do too much work. I’ll have to get the 6112 kit when my funds allow it. Should be an easy swap without having to align it since I already have the 5100 adjustables on there in the max height.
actually that's what you want if you have a good shock.....spring just supports the vehicle and shock is responsible for dampening, spring shouldn't get in the way of shock doing its job....if you have more dampening maybe can get away with lighter spring.....but yeah you want the shock doing most of the work....
Ok needing some help deciding. I have a 2014 Sierra crew cab 5.3L z71. Right now I have a 2" level in front that mounts under the strut (1" in thickness for 2" lift). Nothing in the rear. I have 275/70/18 on stock rims. No rub noticed on pavement or off road.
I have 1-1.25" of rake and I like the way the truck sits. But I want to change the shocks to either the bilstein 5100 or eibach pro truck sport. I'm keeping the stock springs and losing the spacer.
I know what the literature states for what sort of height increase to expect. But I'd like some real world #s. I've read this thread and some seem to be getting more lift than the reported #s. Please let me know your rake with this setup. Thanks!!
the eibach kit with eibach spring sits higher than same kit with stock spring....i believe its about 1" difference more lift....so when your reading stuff note whether its stock spring or eibach….both work on same kit.
Edited by Dunn
Yeah for sure, I'm talking about with stock springs. Just changing the shocks.
1 hour ago, BBinnj said:
not seeing that anymore- showing at $702.99 now...
Just checked. It is.
Well after as much reading as i could do on this Thread I've got everything set up to go on this month on the 26th.
Items are:
-6112 kit for front
-5160's rear
-Kryptonite UCA's (KRUCA13)
-Fuel Blitz 18x9 +1 offset
-275/70r18 Kenda RT
-1" Shackle for rear
-Zone trim plates
2018 Silverado w/ 13k miles
Items are:
-6112 kit for front
-5160's rear
-275/70r18 Kenda RT
-Zone trim plates
You likely won’t need the trim plates. I would hold off on installing them until you get the tires put on
I was planning on that originally but these tires run large for a 275/70r18 at 33.45x11.23. Plus i do plan on taking it offroad so just would rather remove any risk of rubbing at the same time as getting the rest done.
Quick picture after picking it up, will take more tomorrow: 6112’s and 5160’s
Looking forward to more pics? How did the trim plate install go?
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 628 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
