Looking forward to more pics? How did the trim plate install go?
Trim plates went well, looks like if i hadn’t done them i’d be trimming the liner. here’s a picture of the angles on the drivers side 4234796de16a6c00fa3a56c539b41830.jpg
Looking like a solid setup. How’s the ride quality?? Did it eliminate the top out feeling?
Need more side pics! Any pics of the trim plate install?
Side picture 1
Gorgeous trucks.
Im thinking about getting 5100’s to lift my nose up a bit.
These wont stress the upper ball joints, correct?
Is replacing the UCA required with the 5100’s?
No it is not required. If you go any taller than 2.5" then you will want to change the UCA.
That's debatable and also depends on what UCA you have. My front is up 1.25 and I'm ok with the angles but had I gone 1.8 I would prefer UCAs on my 18 with stamped steel units.
Bils don't change the angles that much that you would need upper c arms. Having them would be a plus them wouldn't hurt tho.eres my 14 wil Bils at max height bed loaded with stone behind the wheel wells.
Read his question. Required vs optimal is not the same.
Required? No. Will it wear out the ball joint faster? yes. In my case i replaced it because i preferred to not have the stamped steel UCA design when i take it off-road. plus these are bolt in ball joints which makes the replacement of them much easier when they do wear out. but in the end you can put 5100s without replacing a UCA to answer the question.
Thanks.  What UCA did you use?
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
