I replaced the Bose OEM radio deck (Delphi) with aftermarket D-Din deck (Pyle PLDNV695). I wired it all without all pricey harness adapters.
Everything works great the way it is wired now but,
I was not able to find the wiring schematic to wire the stock steering wheel audio controls to the at aftermarket DDin which has the hook ups for it and can also program it.
Please help!!
P.s.: I have already had extreme success with adding aftermarket amp and sub, wiring aftermarket D-Din radio (using the Bose stock speakers), and bypassing Bose amp with no harness adapters for under 30$.
If anyone has any questions about any of those topics I'd be happy to help so you don't have go through all the research I had to do. I'll save you a hellish headache!
I'm new to the forum. How do I get to the subforum?
Scroll down to the Technical & Advanced section, then post your topic in the "Audio, Electronics, OnStar, & SiriusXM" forum (which is exactly where this topic is located).
Do you have the steering wheel control adapter that goes between your OEM radio harness and your aftermarket harness? Such as the PAC RP4-GM11 or RP5-GM11 or Axxess ASWC-1? Your radio has an input for steering wheel controls, but I doubt can process the signal from GM without some sort of adapter. If you have one of those, then I believe the signal wire it is a light green wire in slot #6 in the green plug at the BCM under the driver side dash. Someone else can confirm. If you do not have any of those I would recommend the RP4 or RP5 which are both plug and play, easy to use and can be picked up relatively cheaply.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
