10 hours ago, SS502 said:
Kevin...read this ENTIRE thread before you spend a dime! There are a lot of variables and research required before this mod can be done. The Z71 in his Denali cluster is a sticker he got off eBay. I would like that sticker but the cluster swap is not as simple as it may appear. Please sift through the thread and what I’m saying will make much more sense!
Thanks for the reply Mark. I have read the entire thread and other than getting the correct part number for your vehicle and the programming by WAMS I don't think there should be any issues. What else do you see? I'm curious. Thanks
I missed the  Z71 on my stock cluster, its a decal I got on ebay
I knew it was custom. Was just wondering how you did it. Very cool!
Oh it sounds like you’ve got it right! Just was trying to help before you pulled the trigger on just any cluster ? the swap is really very easy, sounds like you’ve done the hard part. Enjoy the day!
Wanted to see if anyone could help me here...
I've found the right cluster but it is missing the lens.  Do the lenses need to be a specific part number in order to fit the right cluster?  For example, I have a 2017 Yukon SLT.  I found a new cluster with the right part number but it doesn't have a lens.  I've found some 2017 Yukon Denali Lenses on ebay but I wasn't sure if they are specific to a part number or if I can just go ahead and buy one because its a lens from a 2017 Yukon Denali.  Thanks so much for any assistance here.
As long as the lens is for a UHS cluster (aka Denali cluster), it'll fit but your SLT cluster lens won't fit.
Thank you very much. Now I know exactly what to purchase.
28 minutes ago, Shibbby911 said:
Will the Escalade cluster swap over also?
Escalade cluster does not properly fit (has gaps), has the wrong coloring/images and is more expensive to retrofit. We can do it but we dont recommend it.
Do you guys know if a KPH cluster (assuming it came from Mexico or Canada) can be programmed into my US vehicle?
Edited by z71tx
Edit
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
