13 hours ago, Dodgersfan said:
Owned 1 ford in between my 5 GMs. Column shifter way more comfortable for me, but probably because that’s what I’m most used to. Probably would make sense to make a keyless option if you want to pay for it.
I would love to see GM come up with some kind of combination lock like my ford had. I used that all the time. Able to lock keys in truck while I went to gym or for a run or paddle boarding. I can use onStar, but still have to carry phone. That sucks when you go on water or for run.
It's doable on later trucks.  Maybe '15 and up?
I've always hated the column shifter, these days it makes me feel like I have 3on the tree. I don't like rotary dials either in a truck. A special/luxury/sport truck should have that feel register with everything I touch. These trucks are over 50k, make me feel like paying that note. Leave the push button to Lincoln. Give me a horseshoe, a 'T', a slanted hockey stick. One other thing, any truck costing over 30gs should Have dual horns.
  • 3 months later...
New to GM and I can't believe how much I actually like the "archaic" steering column shifter. It makes so much sense. You always know exactly what gear you're in by feel, don't even have to look at it to shift it, and otherwise stays out of the way and doesn't eat up center console space. No it's not sexy or trendy or "cool", but I think they make perfect sense in utilitarian vehicles like these. I definitely prefer it in my Suburban compared to a floor shifter, rotary knob somewhere, or especially a push button thing. I did have a 1984 Pontiac 6000 that I learned to drive on which was "three on the tree" back then! It had front bench seating so not really any other place to put it. Amazing how my brain snapped right back to column shifter mode, though. I hope they stick with the column shifters.
I haven’t personally checked out the 2019 Silverado.  Can someone that has actually checked it out or even better has bought one attest to what the mode of shifting is?  Also, does it still have key start or does it now have push start?
  • 2 months later...
Push button is more convienient imo because my keys stay in my pocket. I had a h2 before my yukon and going to column shifting has been an adjustment. I feel like i’m going to break it.
Just pulled up 2019 Silverado interior pics, appears to be either an LTZ or Highcountry;  there’s still a column shift.  But, shows Push Start/Stop Button, no key slot.
All Chevy/GMC 1500, 2500 and 3500's are column shift. The Canyon/Colorado have console shifters, though.
EDIT: Should also add all Tahoe/Yukon/Escalade are column shift, too.
Edited by magnum74
The console shifter in the 15-present Colorado looks like a leftover part from a 2005 Malibu.
Well, GM does a lot of surveys and analysis to base their design, performance and other attribute decisions on.  So, they’re aware that their truck customers are two things; the most loyal and the most conservative among the various demographics.  So, I’m guessing that have considerable data  stating that the column shifter is a positive feature or at worse a neutral feature.  I know that I never think about the subject until I come across it in this forum.
I prefer a column shift and always will. I can deal with a console shift but I'm not big on the dial. I don't think a dial shift alone would prevent me from buying a Dodge but it's not something I'd consider a plus.
Yes.  Why take up console space with something you use once at the beginning of your drive and once at the end of your drive 95% of the time.
That was GM's argument when they were discussing the 2019 1500's with a TFL guy in the video TFL put out.
I have mixed feelings about push button, but leave the shifter where it is!
  • 11 months later...
I think the column shifter should stay with the more open concept folding center seat.  Allows for one more passenger when needed and the the main seating is the same as with a console and less room anyway... As to the push button start/stop, its taking a bit to get used to it therefore the jury is still out on it.
I am one to vote for the shifter on the column. I have driven vehicles with the dial or push button, and it is just weird to me. I do like the push button start, keeping the keys in your pocket is awesome tho.
Console shifters I agree take up space that could be used for other activities.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
