Tires and Wheels
I have a '14 Silverado LT. There is no lift on it. 18" tires. I was looking into getting a new set of tires. I hate the stock dealer tires that are on there. I like Nitto Terra Grappler G2 and BF Goodrich KO2. I think that would look weird though with the basic Chevy wheels on there. So I figured I would dish out some more cash for a set of KMC wheels. My question is, should or shouldn't I get a lift on the truck or will it be ok to leave it without?
If you're sticking with the same size tires as you have now than you can put whatever tires you want on it. If you're going bigger like 33"'s or 35's you'll need at least a leveling kit. (And I'm going to assume you mean you have 18" wheels, not tires). Wheel size won't effect clearance with a lift or not, but tire size will. You can get a 20" wheel and still have tires with the same diameter as a tire on an 18" wheel.
Definitely go with at least a leveling kit or, what I did, check out the Bilstein 5100 struts. They can give you almost 2" lift in the front. I run 275 65r18s and really like the look. It does look small at times when I see these k2s driving around with 6-9 inch lifts and 35s, but looks good nontheless.
November, yes I have 18" wheels. So what exactly does the leveling kit do? Am I better off getting like a 3" lift instead since those tires are more beefie or is it dependent upon the look in going for?
A leveling kit does just that, levels it. Usually raising it 2 inches in the front and 1 inch in the rear. It eliminates most of the rake ( hence the name ) and allows bigger tires to go on.
Ok thanks. I was looking at Tirerack for a wheel and tire package. But for some reason the BF Goodrichs that I like are not showing as one of the 'packages' they do for whatever reason. I want to get the KO2 tires with KMC Monster wheels. I'll have to call and see what they say.
For a beginner, like I was, this is what I did after reading 100's of pages on here. I did all my add ons before doing the level and tires. After the add ons I took several measurements on level ground through the center of the wheel to the bottom of the fender and came up with the difference (rake). Then I decided on how big of a level I wanted to do combined with bigger tires. I wanted to keep the stock wheels and keep P rated tires but go the biggest I could find. Went with the motofab 1.5in front spacer and 265/70/18s (32.6x10.7) and it left me with .5in of rake. On my next truck, depending what measurements I come up with, I would like to do a 2in in front and 1in in back and keep between .5 and 1 inch of rake and put aftermarket wheels on probably +00 offset with the largest P rated tire I can find on whatever wheel size I end up going with.
You can run a 33" tire without a level. The only rub you will have is at full lock. I was running my 33's for a couple weeks before my 5100s came in and didn't have a problem. Only rub was backing out of the driveway at full lock and backing into my tight parking spot at work.
  • 2 months later...
Hi guys i have a question i have a 2005 Avalanche z71 4x4 i found some nice 20's from a 2015 silverado i just want to make sure will they fit? the bolt pattern is the same everywhere i look (6x139.7) but the only difference that i can see is the Center Bore for the Avalanche is 78.3 and the one for the Silverado is 78.1 not sure does this affect it?
6x139.7
. Can you post some pics of your setup? Curious to see that tire size.
Go to my gallery, there are a few in there from before and after. Pics don't show much difference 2in total height in front and .5in height gain in back. It looks good next to a stock truck.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
