1 hour ago, BIGDOGx said:
So about that warranty lol...
Not that i won't eventually get this settled and fixed right but any chance we have any gm techs here on the board that could tell me why when i looked into the front grill at my ac condenser that my dealer stated they replaced, that i see what looks like a large piece of silver tape in the upper right hand corner, the tape like hvac people use to seal around sheet metal ducts? I am really thinking my dealer fixed my condenser with tape, yes i said that correctly tape!
Now if that's the case i have the evidence on my condenser currently and paperwork that states very clearly that the condenser was bad and replaced. To me this now becomes a case of fraud that the dealer is committing towards the manufacture. Im am trying to call other dealers and ac repair shops to get a little more info to see if this is common practice or if gm has a bulletin stating to try and fix it this way, still though as i said the paper work clearly states it was replaced.
I would like a little more info before i call said dealer and unleash a campaign of scorched freaking earth on them!
I am a GM Tech. Lol. The problem with the condensers is the weld. The heat from the transmission causes thermal cycling on the combination transmission fluid/oil and AC condenser cooler creates a crack.
The tape... Lol Just as you guessed is... (drum roll) THERMAL TAPE!
What it does is transfer the heat from the weld and doesn't allow it to crack. (even though I have replaced the one's with tape leaking in the same place.)
Hope this helps.
36 minutes ago, BIGDOGx said:
How could a piece of tape with a size of 2" x 4"  only placed in the upper right hand corner that also doesn't look factory and has about a 1/4"-1/2" on the edge of the condenser which looks like it is trying to seal something up be a heat shield. I also talked to two separate dealer parts departments and both stated the condenser does not come with any kind of tape on it. Are you positive this is a heat shield, can anyone else on here please look at your condenser since we have many that have had dealers replace them look to see if yours is the same.
Not saying your wrong but im just not convinced the way this looks that is like this from factory.
edit...
Check that, i just seen your comment to look back, thanks for the info but this looks like one half arsed fix to be honest, literally looks to me like they just slapped a piece of tape on it and said fixed. In any case at least i know that this was not some patch job my dealer did, it is a patch job that gm did unfortunately.
Glad i looked into this before i made an ass out of myself at the service department haha.:jester:
See above post.
Edit If you go to the 7:37 min part of this video you can see the tape on the right side of the condenser where I am installing it.
Edited by carnau
5 minutes ago, carnau said:
show1.gif.2ce852c4c0d10e6be41a4f7e0e6e2f5b.gifshow2.thumb.gif.9c7fb71a8a6608a1e72d10bab0d4569c.gif
Crazy gm has known problems with this part and instead of fixing it they put duct tape on it, lol this is such a half arsed fix i can do nothing but laugh....
That’s funny, I got a 29 year old truck with the original AC in it. I just did the R-12- to new Freon last year. Don’t make them like they used to.
My 85 has everything factory but the compressor. When I changed the motor to a 383 I updated the ac compressor and retrofit the 134.
The replacement takes more than an hour especially if you pull a vacuum and recharge.
The factory tape band aid is what it.
IMHO aftermarket condensers are made much better than the OEM units.
I think I’m n the same boat as all of y’all, as my 2014 Silverado crew cab LT AC just took crap it’s blowing warm/hot air haven’t looked under the hood as it was hot af in traffic that’s the last thing I wanna do right now is look under the hood. Anybody near Dallas get it fix if so how much?
My condenser just took a crap last week. Repair was $730 and that was not at the dealer. Wish I would have seen this first :(
2 minutes ago, RACERX7775 said:
Lessoned learned.  When something goes wrong, always look here first..
You ain’t lying either!!! I always check on here and google before i go to a shop. Just Incase I can do it my self
I usually do. But yes lesson learned. The new condenser doesnt have that thermal tape so I guess fwiw I'll put a piece where the above pic shows. Man this truck has been a money pit since I bought. Last month it was the high pressure fuel pump leaking. That was $1300!
Same here man, bought the truck next thing you know a afm lifter collapsed so I did a dod/afm delete then a tune. Now the AC just took a crap
so I’m it’s hoping nothing major, will see as soon as I take it to get diagnosed
I'm really starting to think about selling my truck and just leasing from here on out, i don't think they are built to last anymore and i truly would rather spend 300 a month on a lease deal then 2 grand here, a grand there and 500 here trying to keep an older vehicle running.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
