This little issue is happening on my truck as well, have a 2019 Trail Boss.  The only thing I can attribute it to is I put in a set of Lumenex Reverse LED's from Dieselled's.  But I can't 100% attribute it to those bulbs as I put them in a month ago and this problem only started now.  Additionally it's very intermittent as it has only happened on two occasions and went away after I shut the truck off and went into a store and came back out.  Super weird.  I am going to check in with DieselLed's as well to see if they have heard of this.
Well so far, I can say it is definitely moisture related, as it only does it after rain/snow./wash, and then only intermittently. I'll keep hunting it, eventually I'll get there and figure it out.
It's a connection issue for sure.
Led light bulbs shouldn't matter
Sent from my Pixel 3 using Tapatalk
I took mine apart and inspected the connectors that appeared to be slightly corroded for lack of a better word, the connectors had some residue on them.  Anyway I cleaned them off and put some dielectric grease on the connectors to seal it better and make sure the connections are true.  It made a VERY slight difference in that now my display only flashes the backup camera briefly and then immediately goes back to normal.  I don't think it's weather related as over the past few weeks we have had rain, severe cold, snow and now mid 60's and sunny and it has behaved the same through all this.  My conclusion is there is something wonky with the way the wiring is connected in the rear and adding LED backup lights definitely disrupts it.
Agree, have had LED back up bulbs for 2.5 years in mine, never any problems.
Which lights were/are you guys using without any issue, I was using the (921) LUMENEX LED REVERSE LIGHT KIT.  Which I will confirm was the problem as I pulled them back out today and the problem has gone away.
Guys , I’ve had my truck since brand new 2 km on it when I got it (2017 seirra) had leds and light strip on it since new , check the connections under the truck above the spare tire , they get water in it causing this to happen
hope this helps
These:
I pulled the Lumenex and installed both the JDM ASTAR Extremely Bright and/or Super Bright LED's and had the same problem with both sets.  JDM atleast responded to my Customer Service question, they mentioned how LED's have such low resistance that it somehow impacts the electrical system on my Truck and triggers the backup camera.  They suggested putting a 6ohm resistor inline with the LED bulbs to try and correct the problem.  I have not tried that yet.
SOLVED, Finally!!  3 pairs of different Reverse lights, same issue across the board.  For my 19 Silverado Trail Boss, it seemed to be primarily related to the Right Rear as through all the troubleshooting when I put the original stock bulb back in the problem went away.  Anyhooo this is the fix:  https://www.amazon.com/gp/product/B07HF47RV9/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
iBrightstar 50W 6ohm Load Resistors - Fix LED Bulb Fast Hyper Flash Turn Signal Blink Error Code $7 Bucks.
I clipped the green wire, put one of these inline and Voila.  That being said I went all the way back to my Lumenex bulbs since they were by far the brightest ones I have used.  What a dang headache I am so happy to be done screwing around with something so trivial!!
  • 9 months later...
Still no issues? My truck developed this issue for the first time this morning. I believe it may be moisture related as we just had two days of rain that has changed over to ice. When it warms up and dries out some I’m going to check all my connections and add die electric grease to them.
On 1/8/2021 at 7:32 PM, rastasquid said:
Bringing this old one back. Im having this problem now too. Anyone else ever have this and resolve it?
I am Experiencing this issue now also, but 2020 Silverado WT. I believe, like the OP, it is water on a connection. It started after a springtime rinsing trying to remove lots of salt.  Going to check it out rn…
edit: still an issue
Edited by 16-K2XX-WT
This is certainly not what we like to hear, 16-K2XX-WT.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2020 Chevrolet Silverado. To do so, please send an email to [email protected] with ATTN: 16-K2XX-WT/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
