59 minutes ago, Jstnelson said:
Just an update after driving a few hundred miles; clamping the resonance free pipe is a definite sound improvement. I highly recommend a Flowmaster super 40 and clamped mesh inserts. It gives a great tone outside the truck and, while driving, you can clearly hear a good V8 exhaust tone with no drone at all and still pretty silent on the highway. There are a couple speeds that you can steadily hear an exhaust tone while cruising but it never drones/resonates within the cab.
Revving the truck with stock exhaust sounded like a vacuum cleaner.
Revving with Flowmaster Super 40 and stock axle-back had a good tone but sounded like someone was holding a pillow over the tips. You could convince me it was a stock exhaust if I didn’t hear a cold start.
Revving with Flowmaster Super 40 with closed off mesh resonators sounds loud and mean. Definitely sounds aftermarket.
I think you nailed the description!
with my Magnaflow it sounds great now but I do hear when it’s a 4 cyl under low load. Keeping the shifter in “7” it stays in V8 mode and is awesome. Once the DFM bypass is released it’ll be perfect.
I may experiment with different combos of taping the mesh just for kicks. Then I’ll seal em up for good. Amazing how they work really.
So are these trucks with the mesh screen all US designated trucks?  I have ‘19 Silverado High Country it’s a US built CANADIAN truck but I clearly have resonators... and a YUUGE muffler, with adaptive valve on either side.  I want a more v8 sound, but not loud annoying rumbles (I have my 70 Chevelle for that ;)
What’s the best course?  Factory GM cat back?  Cut the resonators out and see, or swap the garbage can sized muffler for a magnaflow or something.  Definitely going to do a CAI, is the GM one the best option?  It does look sharp and factory
Did you ever try it? I was wondering same thing.
My 19 HC also has resonators like this.
No I haven’t yet! Lol I was hoping someone had cut there’s off first.  I might have to soon can’t stand this rattle tin can sound.
I did it on my JK but a little different beast. Sounds great for a V6[emoji12]..I want to cut them, but kinda got a few things in the works with the truck. So I'll have to wait[emoji853]
i cut those stupid resonators off and put a flowmaster 50 on in place of the muffler. getting some sound but not too loud. cost about 400 bucks total. they put pipe in the place of the resonators.
oh to clarify, i put the flowmaster on first and made ZERO diff. had to cut the resonators off to hear anything. guy at the muffler shop had never seen such insanity.
Edited by Trail Boss 1
About a month ago I had a local shop install a Super 40, and it sounded better than stock but not better than the Super 40 I had on my 17. When warm/hot starting it would make a fluttering sound, and it was horrible. After reading these posts Sunday evening I went to Lowes and bought 12 Stainless Steel Hose Clamps. I cut up 3 beer cans into 3.125" squares to cover the 6 Resonator spots, using the clamps to hold them in place. WOW! What a freakin difference! I love the sound, and it was fairly cheap and easy to do. No more warm/hot start fluttering too!
I covered mine up tonight with 6 clamps that were 2 3/4 in from home Depot and used a $7 piece of galvanized steel from the HVAC section and cut them in 2 1/4 x 2 1/4 squares.
Even though it was a warm start, I would agree it definitely added a few decibels and some additional growl to the 5.3 on my trail boss. I can't wait to do a cold start tomorrow to hear the difference. I will probably also clamp open the flapper valve as I found on my 16 z71 that also increased the stock sound.
I was thinking about using the heat wrap like you see on motorcycle pipes. I wonder if they would block enough flow to make a difference in sound?
Cold start this morning was definitely noticeably louder from the outside. I could hear a little rumble inside the cab, but as I suspected the hum of the duratac tires I have completely drowned out any increase in exhaust noise. If you had regular street tires, you could probably hear the difference.
It did sound a touch louder on hard acceleration getting on the highway.
For the $10 it cost me, sure sign me up.
What type of clamps did you use?
  • 5 months later...
Anyone do this on a 6.2?
I believe the 6.2 has actual resonators which have to be cut out.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
    • I read through that and I won't lie, my eyes rolled at some of the quirks about how it can turn off the trailer braking for example but I can see how it could help control or even up the torque applied to the ground with each wheel in a boat ramp scenario. But of course what it can't do is increase the torque to the wheels if the need is there as it ends up being like driving the four wheel drive version of a two wheel drive ( high range that is ). So far the neighbor that ended up with the 3.0 duramax with the max tow package which meant the 3.73 gears and high range only, I think its been doing ok for what he has been towing but doubt he ventures off into the soft stuff with his holiday trailer. He may have towed his dads river boat locally with it ( he always used his 6.6 duramax before ), I'll have to ask him sometime if he got into a lack of power to the wheels situation as after all that engine produces a lot of torque at low speed once the turbo winds out a bit and I think it has the 10 speed and if so they have a pretty good first gear ratio at 4.70 I see which is vastly better than the 3 or four speed overdrive models of years ago.
