Just now, dctackett10 said:
Nice!  Did you do the trail boss emblem or it come like that?
Thanks.  I did it using black letters
Finished my Onboard Air project and painted the tow hooks>  I gained like 50 HP with the red paint lol.
Tow hooks (I can't seem to load more than one pic due to file size- anybody know a free photo sharing site now that photobucket charges?
I thought about painting my tow hooks. I really dig the red on black like the trail boss’ have. Did you remove them or just paint them while they were on?
On another note. I’m looking to add just a little more noise to my exhaust. I have a 2019 rst z71 crew with the dual exhausts. I believe the muffler goes one in and one out but I have to look again. I really really don’t want to hear drone too much. I’m also afraid of the chopper noise everyone talks about with the flapper. Should I keep the flapper on to avoid this? Or, will it not make much difference if I chop it out and replace muffler section? This is my first Chevy and v8 so I’m new to this world. Coming from an 18 f150 with the 2.7 (lemon) im super happy with my choice. I will never ever go with ford again. But that’s another story. Thanks
I took them off- only 2 (18mm?) bolts each.
30 minutes ago, Thejet07 said:
Ahhh man. That’s exactly what I wanna do. Spray paint?
Yes- just cleaned really good and 4 light coats of rustoleum "apple red"  If it doesn't hold up I'll just get them powdercoated for a few dollars more.
I don’t know how much powder coating costs but you can just buy the OEM red ones on eBay for $50 and then get most of your money back selling the black ones to someone who hates their red or chrome hooks. I have a line out the door for my black ones. Unfortunately I have to somehow reach in there and cut the bolt on the drivers side because a shroud blocks it from coming out far enough, so I’m kinda dragging my feet...
  • Thanks 1
I gave mine a bath for the first time.  This thing is huge compared to me 2002.  Got out my step stool and went to town.  The grill sure is fun to clean and then dry off.  Might just break out the leaf blower next time to help get most of the water off.
Speaking of tow hooks.  If anyone wants to swap their black ones for my chrome, let me know.
Edited by Black02Silverado
Hahaha. So did I.  Had to get that step stool out to wash the hood and windshield lol.
Ceramic coat that grille [emoji16] did my Camaro and it makes it easier to clean
Ryan B.
https://www.autoanything.com/car-care/77A3935A3070949.aspx?
They are awesome for grills, wheels, etc. Think they also make a smaller, cheaper handheld one.
3 hours ago, Black02Silverado said:
That thing cost more than my leaf blower.  LOL
I have the bigger version and I love it, works awesome, will never use a leaf blower again.
Master Blaster
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
