Yes slightly. I used VViViD vinyl but I know 3M 1080 is a little thicker but harder to work with but it might hide it better.
Can you post a pic from further back at the rear?
7 hours ago, MacLaren said:
Added the tailgate lettering today
Looks nice. Are these the chrome plastic ABS letters or the soft flexible rubber like letters from BD Trims?
Thank you.
They are the domed version from BD Trims.
They fit absolutely perfectly too.
Edited by MacLaren
Installed Iconic 41 boards and floor runners.
Edited by Bert Rawlings
15 hours ago, Kris Ward said:
How difficult was this?  Online it says you have to remove the grill to install.
Just make sure to keep super glue handy. Broke my little plastic clips on the grill taking the original symbol off mine when I did it. Superglue fixes it right up.
1 minute ago, RyanbabZ71 said:
Waterless wash
Ryan B.
Which one do you use? I’ve tried Adams, Meguairs, and Aero Cosmetics. So far I think the Meguairs does the best job. The Aero is by far the cheapest but does seem to leave a few streaks.
Ceramic Coating complete. Will cure overnight, and I'll pick up in the a.m.
  • Like 4
Adams, I also use their new ceramic waterless wash it works great
Sent from my iPad using Tapatalk Pro
I have used Croftgate water-less car wash products for three years, best I have found.  https://www.croftgateusa.com/
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
