ive decided to go another route with this.  So i have a switch for sale if anyone wants it.  blue light p/n: 2331721860281139
pm me if interested
Edited by 14tungstenLT
After all that, you are gonna give up now? Lol. What "route" are you gonna take? If its the wiring of the relay, it looks intimidating, but truthfully, its easy. And once its done, you are gonna be like, wow, that was easy.
I wish to do this to my 2500 hd
but would like to run it through  x50a
does any one have the full wiring drawing for this circuit
Edited by Bernard Sarazin
spelling
On 15/09/2018 at 2:52 PM, TinkeringFox said:
Have you seen the Michael J Fox Edition Sierra/Silverado rolling down the road? Looks like the Toyota from Back to the Future. Anyway there is a really cool headlight switch with the option for Off-Road lights. Apparently with a long push of the button the BCM will latch the signal and provide a constant positive signal for triggering a relay. It will also illuminate the icon on the switch as well as send a signal to the cluster illuminating an amber light icon next to the fog light icon or “ORL” in amber.
I successfully installed this in my wife’s ‘16 2500 Denali yesterday but from what I’ve read it’s the same for 1/2 tons, HDs, and Colorado/Canyon.
The BCM already has Programing for this from the factory but I’m not sure when (how early) it was started. I have a ‘15 3500 that I’ll try soon as well as a friend’s ‘17 2500 to do soon.
If the Programing hasn’t been done in my ‘15 I’ll still be able to get the switch to illuminate as well as latch a signal for positive or negative relay signaling using a latching relay.
There are several variants of this switch. Some have blue background for ‘17+Up model years and red for ‘16+earlier. Additionally some have the ORL switch without Fogs, and some have no surround backlighting.
Here is the video from yesterday’s install.....
......More videos to come for other uses like work lights, incorporating into the X50A, rear facing lights, non programmed trucks.....
Pgamboa has been very helpful in discussion about this as well as providing schematic-Thank You!
The OEM drawings are for use with a relay provided with a harness that circumvents the X50A. The problem is that the X50A upfitter relays use a negative signal or “trigger” to energize. There is a way around this though. Is your truck a gasser or diesel?
46 minutes ago, Bernard Sarazin said:
diesel and I have added the four upfitter auxiliary switches.
I would like to make it as close to own as possible
The reason I’m asking is that there is an unused  “fuel pump 2” relay in some vehicles. I believe this  relay uses a positive signal to energize. Check your fuse box for it. My wife’s ‘16 Duramax doesn’t have the relay or the pins to support it but my ‘17 Duramax does as well as my ‘15 6.0.
could you not go through the bcm to the relay panel
The power or signal wire already is coming from the BCM. Since it’s positive it won’t be able to trigger the X50A upfitter relays. You could feed it through the X61A junction block and then out to the X50A to keep the harness clean but it will still be a positive signal.
I’ve just installed the switch and wiring into my 2018 1500LT. Light bar come tomorrow and looking to have everything fully installed Friday so I’ll post photos. Working on a solution for the active front shutters as they make the behind the grill install a little more challenging.
Edited by jaxsilverfox
Addition of photo
Please do.  I haven't gotten a light bar yeat because of the active shutters.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
