On 5/2/2019 at 3:15 PM, RyanbabZ71 said:
Ryan B.
I thought you were getting it with the gm lift?
It’s dealer installed.
Ryan B.
Ryan B.
Oh ok. I thought when it was ordered with it the factory installed it.
Only the trailboss and AT4 are factory installed.
Ryan B.
Finished my paint Protection wrap using 3m pro series matte film. Then had the new wheels installed today.IMG_20190507_183026.jpegIMG_20190507_183034.jpegIMG_20190507_183017.jpeg
Sent from my SM-T813 using Tapatalk
  • Like 7
yes they are fuel vapors. Offset is +20
I went conservative on the tires and kept the stock tire size 275/60R 20 General ATX.
How do you like the ATx?  Good on the highway?
They seem pretty good. Not loud not much different than my stock wheels. With that said...... I have only driven about 100 miles since they were installed.
Cleaned up and ready to go!
I dont know why but this angle really reminds me of the 99-02 body style. Love it!
Sent from my ONEPLUS A6013 using Tapatalk
It does have a subtle GMT800 style.
I am surprised how the Sierra is growing on me... Looks like equally good deals on either the Chevy or GMC so maybe in a couple of years when the time comes I'll go back to a GMC...  Probably an SLT Crew Cab 5.3...
On 3/19/2019 at 6:41 PM, Schmoe said:
https://www.calipercovers.com/vehiclesearch/result/index/make/24/model/341/year/55/submodel/291
they are supposedly working on getting licensing rights to allow them to create the AT4 logo, but I just went with the GMC logo cause I was impatient. Lots of color options, also.
Did you go with the standard red color with the GMC logo?  How close does the color match the red tow hooks?  Sorry, I’m a bit anal...  thanks!
    • Those are parts changers. It can get expensive though. I was a mechanic for 30 yrs. My truck has made this noise since new. I really don`t know what it is. It really doesn`t bother me. I`m still in warranty but have not brought it to the dealer.   I`m not buying the oil pump prime thing. Screw the TSB. I believe it`s in the trans pump gears. They rattle when that piss poor ULV oil drains off after a while. I believe those sharp tooth gears, with backlash, can rattle when dry. Not a vane style oil pump. Wonder who`s right? Me, or the TSB?🤔   Maybe I`m wrong?
    • Sounds about right. I miss the days of mechanics lol.
    • On the PCM side, blue PCM connector, pin 18, solid gray color (no stripe) wire circuit 435.  That is the EGR low circuit which an issue on that line (be it the wiring, the PCM or the EGR valve or system performance) will trigger P0401 when it tests that code.     There is also a VERY old TSB that states to make sure you clear the DTCs ANY time the PCM is unplugged, reprogrammed, or if the EGR valve is unplugged or replaced as the PCM has an auto zero function in the PCM for the EGR pintle data   61-65-59: SMU - SECTION 6E - ENGINE CONTROLS - CLEAR DTC'S - (Nov 25, 1996)   "CLEAR ANY DTCS FROM THE VCM ANYTIME AFTER DOING VCM REPLACEMENT/ PROGRAMMING, TURNING THE IGNITION ON WHILE THE EGR VALVE IS DISCONNECTED, OR REPLACING THE EGR VALVE."   Some diagnostic aid notes in the GM diag on P0401 for a 1995 S10 Blazer:   Diagnostic Aids Notice: In order to prevent further damage if the EGR valve shows signs of excessive heat, check the exhaust system for blockage (possibly a plugged converter) using the procedure found on the restricted exhaust system check. If the exhaust system is restricted, repair the cause; one of which might be an injector which is open due to one of the following reasons: Stuck Grounded driver circuit Check the oil for possible fuel contamination if a stuck open fuel injector is found. Poor connection or damaged harness - Inspect VCM harness connectors for the following conditions: Backed out terminal BL 18 Improper mating Broken locks Improperly formed or damaged terminal Poor terminal to wire connection Damaged harness Intermittent test - If connections and harness check OK, monitor a digital voltmeter connected between terminal BL 18 and ground while moving related connectors and wiring harness. If the failure is induced, the voltage reading will change.
    • maybe get a service manual off ebay?  or check charm.li (website) or subscribe to alldata.com for it?
    • This biggest difference in a HM oil is in contains some  "Seal Conditioner". DEXOS oils and most shelf oils are "Dry" oils which over time harden seals. "Seal Conditioner" is more times than not, an Ester. Addition will soften the seals over time but will not repair one that leaks or has cracked. Esters also provide some cleaning but these HM oils don't contain enough to solve out hard deposits. Just the soft stuff.  Also a function of an Ester.    Ester's are not 'allowed' as a 'co-base" by license. Weird, right?  A certain amount is allowed as an additive. Bunch of game playing is what it is. It's why HM oils don't have a DEXOS approval.    DEXOS is a license 'with' a specification but is not a specification. Never was, never will be. It's GM's slot machine always paying the house. Use what you like.
