The system in the Silverado sucks.  Can't be good for the engine to shut down for half a second at a stop sign before I take my foot off the brake and it starts up again.
The only system I've driven that I like (a lot) is the one in my wife's Chyrsler Pacific Hybrid.  But that's a full plug in hybrid.  Once the battery runs out and it goes off full electric, the engine is starting and stopping all the time, but it is completely seamless, you don't feel a thing unless you are really trying to pick up on it, or looking at the gauge on the dash.  If they put that system in a Ram truck I will switch back to Ram.  We've had the van over a month and she has used barely a quarter tank of gas.
Easy fix:  Autostop Eliminator.
Not sure if this has been mentioned before, but the extra paint protection that I think comes with the Z71 edition.
Question for the thread...
What's this little white arrow in the upper right corner of the DIC when the truck ignition is off? I push on the steering wheel DIC buttons, but nothing happens. Anyone know?
When you start playing audio on your phone, the radio will automatically switch over to bluetooth to start playing it, no need to manually push the bluetooth button first.  My 2017 didn't do that.
1.  The remote start run time is exceeds 9 minutes, which was the run time on my old 14 Z71.  Does anyone know how long this run time is?  I've let it go up to 11 minutes before I've started the 19 LT Texas Edition.
2.  NOT COOL FEATURE:  AC dripping on exhaust sound.  What's up with this?
3.  Emergency brake turns on on its own sometimes when I park.  Is this common to other 19 Silverado users?  The push button E brake is cool.
On 7/15/2019 at 6:40 AM, Thomcat said:
The OnStar hands free calling is no longer hands free on the '19! Instead of responding to voice commands after pushing the OnStar button, the 8" screen shaos a touch keypad where you have to enter the number.
I wasn't aware anyone still bothered with this given that basically everyone has a phone with bluetooth. Why pay extra for OnStar calling when you should be able to do the same, assuming you have a smartphone?
1. 15 minutes.
2. Common on a lot of vehicles sadly.
3. Probably a hill-hold feature if you park on an incline? Just guessing.
3. Mine does this every time I park in my driveway, which is at almost a 45 degree angle.  It's definitely a hill-hold feature as mentioned above.
I have noticed the same.  I've never been a fan of the push button electronic parking brakes -- but this is a really good application for them.  On my last truck I'm not sure the parking brake ever got engaged except maybe the couple times my wife drove it.  But I probably should have on hills, so this saves me having to remember.
Just guessing -- maybe an indicator to show you that you can press the arrow button on your steering wheel to get into menu options.
I’m ok with it as long as it doesn’t freeze in the winter. [emoji1787]
1. 15 minutes.
.02  Think of this as a spare tire, not worth the reduced mileage dragging it around and serves no purpose until you need it. Bluetooth is nothing more than an interface with the cellphone...it is the cellphone and not the more powerful carphone that connects to a cell tower. Might not make a difference driving a city grocery-getter with a cell phone tower on every other corner. But not when out in the real world with wide open spaces, mountains, deserts etc. with limited towers. A cheapo provider with sporadic coverage and a cellphone with its'  miniature antenna and limited pi$$ poor power output so it doesn't fry your brain gets you no bars somewhere in an unknown ditch after an accident whereas the more powerful built-in phone with the roof wart mounted microwave antenna will be enough to get your signal out and identify your location.
I noticed that when I answer the phone on Apply carplay, it lowers the AC to quiet it down a bit.  I thought that was neat then noticed when making a call it does not lower the AC until they answer, so you still get full power when it is ringing.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
